I need zong puk code?
SOURCE: me apna pin code bhool
Kindly contact your service provider.
The PIN code supplied with the SIM card protects the card against unauthorised use. The PIN2 code supplied with some SIM cards is required to access certain services. If you enter PIN or PIN2 code incorrectly three times in succession, you are asked for the PUK or PUK2 code. If you do not have them, contact your service provider. The module PIN is required to access the information in the security module of your SIM card. The signing PIN may be required for the digital signature. The barring password is required when using the call barring service. To set= how your phone uses the access codes and security settings, select Menu> Settings> Security.
Thanks for using FixYa
All the Best!
SOURCE: HOW CAN I UNLOCK GLOBE SIM CARD PUK CODE?
hi pretty,,
you may call your network provider regarding on this Dial 211 on your cellphone. The operator will assist you by telling that your SIM was blocked and it need a PUK code.
you must provide the Number at the back of your SIM card, you will require to give this to them, to be able to retrieve the PUK code for that SIM.
Hope it helps.
Thank you for using fixya.
SOURCE: my mobile(Nokia 1650) sim is been blocked by my
noone can help you in this only your network customer care service will help you
first call them and tel your problem to them they will give you a puk no. for your no.
SOURCE: sir my aircel sim has been
The puk of your sim is found on the sim certificate and the pin code is 0000
SOURCE: sir,\r\n my aircel sim is blocked & ask for the
You can get the puk code from aircel customer ....So just try to call toll free no...
