Question about OKI C5800dn Laser Printer
C5800 incompatable ink
Just changed the cyan cartridge with oki brand, but printer not recognising it. How do I fix this?
5 Related Answers
Anonymous
  • 141 Answers
SOURCE: Oki c5800 laser printer
http://www.c5800.co.uk/index.asp?printername=C5800&menumode=0&content=C5800downloads
At the bottom you will see the file C58uEN1.pdf
Go to page 89
Posted on Mar 26, 2008
Anonymous
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
Anonymous
SOURCE: How do you reset the OKI c5800 drum?
You don't need to go through all that mess of replacing the fuse. The tone gets everywhere and getting the Drum unit back together with all the gears and shafts lining up is a real pain.
The Drum reset system is very simple. When the printer powers up and runs through its system check, one of the tests energizes the erase LED array built into the Drum unit. The reset fuse routes a small amount of low voltage current off this LED array. There is a contact on the end of the Drum unit that the printer senses. It there is voltage there (ie the fuse is good), the printer resets that Drums counter to 100%. If there is no voltage (ie the fuse is blown), the printer continues on its way.
All you have to do it act like fuse at the instant the printer sends power to the LED array.
There's no soldering, no screws to undo, and no toner all over the place.
The best thing is it takes about 3 minutes start to finish and cost $0.00!
Here's what you need:
• A simple volt/amp meter (an analog one works best, but digital is fine also) • Two pieces of thin wire about 300mm long. I used old telco wire. With insulation, its about 1mm wide. • A pair of scissors to strip the wire ends • X-acto or thin razor knife
1) Strip about 4-5mm off the one end of each wire and 25mm off the other end. Bend the 5mm end at a 90 degree angle right at the base of the stripped part. 2) Pull out the Drum unit (leave the toner cartridge attached to the Drum unit) 3) On the right end of the Drum unit (DU) there are three square brass contacts about 3mm wide. The right end is the end with the blue handle. Looking at the end of the DU, you are interested in the 1st and 2nd contacts from the left (they are the two closest to the screws on a c5800 cartridge) 4) Use the X-acto knife to lift the contact metal and slide the 90 bent end of the wire under the contact. Do this with the other wire on contact #2. 5) Put a little vertical tension on the wires and route them around the blue toner release handle. 6) Gently insert the DU/toner cartridge into the printer. Keep slight tension on the wires until the unit is seated. 7) Wrap the 25mm stripped end of the wires around the volt meter leads. Wrap one so it makes electrical contact, but you could pull it apart instantly at the right time. 8) Set your voltmeter to the lowest amp setting. I put mine on 200micro amps. Also make sure your voltmeter leads are in the correct holes of the voltmeter. You want the amperage or milliAmp holes not the voltage holes. Don't forget to turn the meter on. 9) Get prepared to pull one of the leads off of the one of the thin wires and turn on the printer. Don't be afraid to touch the metal of the wire; the voltage/amperage supplied to the LED array is very low and will not hurt you. A 9 volt flashlight battery is more dangerous. 10) About 10 seconds into the startup routine, you will see you voltmeter display a reading. Instantly pull the leads apart.
Congratulations, you are now officially a 1/16amp fuse.
Your printer will reset the Drum Unit counter and you have another 20K impressions (if the image quality is acceptable to you)
If you have any question, just respond to this post. I'll get the email and answer you.
Good Luck.
Paul
Posted on May 22, 2010
Michael
  • 77 Answers
SOURCE: I'm getting wide blue streaks
remove the cyan toner and drum. look for a stripe on the drum unit, if there is the unit has failed.
Posted on Jan 11, 2011
Anonymous
  • 47 Answers
SOURCE: I just replaced the cyan and black tonner in my
use an OEM toner and
8. Restart printer.
Posted on Mar 01, 2011
Oki c5550 INCOMPATIBLE YELLOW
Are you using factory or aftermarket toner?
Jan 07, 2014 | Oki Electric Industry Okidata C5550n MFP...
Espson Stylus D92 not recognising cartridge change
Do replacement procedure, follow How to.. on status monitor. When asked to replace ink tank, unplug all ink tanks, and plug only cyan ink tank. Next....next.. Finish. See status monitor. Is cyan recognized (Not cross sign)? If yes, repeat procedure, without unplugging, plug others 1 by 1.
If no, check for chip connector (for cyan) at carriage, or try to use another cyan ink tank.
Sep 20, 2009 | Epson Office Equipment & Supplies
Ink in hp photosmart 3310
the printer should have software installed enabling you to opt, for a printer-ink cartridge change.
If the cartridge has a chip fitted, it may be discharged.
The chip is supposed to be charged up, for the printer to recognise the newly installed cartridge.
view your settings in control panel/printer/properties to see what options you have available.
Mike @ Compurepair.
Jul 23, 2008 | HP Photosmart 3310 Printer
Problem using sublimation inks
Since you are using sublmation ink, the cartridges are probably aftermarket and may not meet Epson standards. Aftermarket chipped cartridges are notorious for failing to 'communicate' with Epson printers, even when the cartridge is brand new. Before taking the printer to a service center, you might try purchasing new cartridges of your ink from your reseller. If that fixes the problem then your fight is with the ink reseller, not Epson. If it doesn't fix the problem and your printer is still under warranty, take it to an authorized service center, and remember, using non-Epson ink does NOT void the waranty.
Jun 16, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Cyan ink tank not recognised
I phoned Canon Tech Support Center this morning. They had me replace the ink tank giving me the U150 error code and are sending me a replacement tank. HOPEFULLY this will solve the problem.
Oct 27, 2007 | Canon PIXMA MP510 All-In-One InkJet...
OKI 5400DN
just check the cyan leeds head and clean it, or check the cyan drum.
Nov 07, 2006 | OKI C5400dn Led Printer
OKI C5800dn Laser Printer Logo
22 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
