Kenmore model 417.93042300 gas stackable dryer was working fine. Suddenly, there was no heat. The dryer drum turns but there is no heat. Instruction manual states there are two fuses inside & to check & replace if one is blown, replace it. Where are the fuses located, and how do I get inside to check & replace it?
The gas burner assembly uses solenoid coils in a circuit with the flame sensor to safely ignite the burner. When the dryer starts a heated cycle, the circuit through those components is energized. The igniter glows until it reaches the proper temperature to ignite the gas, at which point the flame sensor trips open and the current flowing through that circuit is diverted to the gas valve coils so the gas valves open, and the burner lights and continues to burn. If the solenoid coils on the gas valves fail, the gas valves won't open for ignition. If the gas valve coils are weak, the burner lights during the initial ignition sequence from a cold start but it fails to light the burner on subsequent ignition attempts. In this situation, replace the valve coils. I Had the same problem with mine and I fixed for like $25.00 US. Its not hard to do look at the video. Either buy your part from them or to get it fast and not out of this world go to "repairclinic.com
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
Hello hboiler
Welcome,
You asked ,where can you download the owners manual for Sears Kenmore Stackable Washer/Dryer Model #417.91042000 and #417.41042000
Model #417.41042000
http://www.managemyhome.com/mmh/products/ManualSearch.action?product.brandName=Kenmore&product.modelNumber=417.41042000&intcmp=A5
Model #417.91042000
http://www.managemyhome.com/mmh/products/ManualSearch.action?product.brandName=Kenmore&product.modelNumber=417.91042000&intcmp=A5
Happy to help you!
Thank You for using Fixya.
Huuum
Please remember to leave a solved rating!
SOURCE: Dryer works and tumbles but does not heat
First, you must remove the front panel. Open the door and remove 2 screws on each side of the opening; 2 in the door hinges and 2 directly opposite from them. Then close and latch the door and pull on the top corners of the panel and it pivots down, then lift off the bottom brackets. Then start the dryer (making sure it's not set for air fluff or no heat) and watch the ignitor to the left side of the burner tube. Report back if it glows or not. Also you might include the first two numbers of the serial number so I can make sure we're talking about the same series machine.
SOURCE: dryer spins but does not dry clothes
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the
side may be plugged. You have to pull the machine out and clear
that pipe or rebuild it out to a soffit vent or static vent if it is in
the attic, or out through your crawl space. This will make a huge
difference. If that hot air and moisture doesn't get out of the
machine it just goes back into your clothes.
Good luck!!
SOURCE: my kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
This is a dryer
