Question about Sanyo DP26640ARB 26 LCD HD TV 720p Refurbished Unit 1 Each
Watching tv and sound goes out - Sanyo DP26640ARB 26 LCD HD TV 720p Refurbished Unit 1 Each
Posted by Sheri Rigsby on
Parasuraman S
    Genius:
  • 1,182 Answers
First of all ensure that the the problem is not on the input device by connecting it to another TV. Try using a different input device. If nothing works, better refer it to a qualified service technician.
Posted on Jul 19, 2012
Screen goes blank while watching TV and playing DVDs
First thing to do is replace the cable with a new high quality one. They can go faulty. If that doesn't work, check that you are outputting the correct signals from your devices, plus it is set to pick them up. If that doesn't work you might have a fault possibly on the TV.
Mar 19, 2017 | Marantz NR1602
The sound goes off after watching tv for some time
It sounds like the power amps is heating up and shut down, try attaching powered PC speakers the AUDIO Line out RCA jacks and see if sound stays on, if it does, you have problem in the power amp sections.
Nov 02, 2009 | Sansui 19 in. LCD TV
40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Jul 15, 2009 | Westinghouse Electric VK-40H580D 40 in....
Watching tv sound goes static
Hi there, this is a tuner issue. it can be repaired or replaced.
Feb 20, 2009 | Philips 47PFL3603D LCD TV
Watching tv and screen goes black w/no more sound!
you can check only for the fuse if it is busted or not
locate the fuse. check if it open using a tester.......
if you have no experience yet on electronic servicing then you can fix it.
Nov 13, 2007 | RCA TruFlat 27F520T 27" TV
Sound proublem in TV (Thomson make)
1 it might be due to spraker wire loose or its connector loose. 2 loose contact in sound section. 3 some cap faulty. 4 sound ic might be grtting more supply so ic is getting over heated. 5 sound ic might be defective.
Oct 04, 2007 | Televison & Video
Great sound no picture
When I turn my tv on there is one certain channel that goes black after watching less than 5 minutes. this might be due to electronic tuner or loose contact in that particular section. 100% problem will be solved thanks
Sep 09, 2007 | Sanyo DS24205 24" TV
Sanyo DP26640ARB 26 LCD HD TV 720p Refurbished Unit 1 Each Logo
16 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
