This is what I came up with. Just pass the screw through the nail puller in a flat bar. Use a block of wood to protect the door, and press down on the other end. A lot easier than anything else I've tried.
Very easy unless the old spring is blocked /or stopped for the foam insulation , you have to take both hinges and than with needle nose plplies pull it out , unless the FOAM STOPPED IT , than use different approuch you have to take the pannel off and cut around the spring . good luck,
