Question about Hotpoint Ultima WF865 Front Load Washer
NOT SPINNING WASHING IS NOT SPINNING
Posted by ANN MAXWELL on
ernesto cuadra
    Top Expert:
  • Hotpoint Master
  • 12,223 Answers
1) test the belt broken or worn replace
2)door switch, test for open or defective
3)main control board or CCU, test for loose wires connector, if fail the CCU is faulty, replace
4) motor control board , is located near to the motor,receive information from CCU, tight all wires connector, for loose, otherwise you must replace the MCM
Posted on Jul 19, 2012
Not spinning properly there is still a lot of water in clothes after spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Admiral Washing Machines
Washing machine is washing but not draining or spinning
heatman101
Apr 26, 2011 | Indesit W 123 Front Load Washer
Washing normal, rinsing normal, but not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 18, 2011 | Washing Machines
My machine is washing but don't do the spinning
heatman101
Apr 17, 2011 | Washing Machines
My whirlpool AWOD4606 washing machine won't spin when washing or spinning
heatman101
Apr 13, 2011 | Washing Machines
Not draining n spinning. incomplete washing cycle.
heatman101
Mar 16, 2011 | Washing Machines
The washing machine is not spinning
heatman101
Dec 28, 2010 | General Washing Machines
When its time for my washing machine to spin out...it sounds like its spinning, but when you open the lid...the water is out...but the clothes are still wet and the machine is not spinning
heatman101
Aug 29, 2010 | Roper RAS8445KQ Top Load Washer
Washer isnt spinning out does drain but not spinning at all
heatman101
Aug 29, 2010 | Washing Machines
Washing machine is not spinnig out the water
Does your washing machine spinning? if the washing machine is spinning and the water won't out, the release valve didn't open.
If the washing machine is not spinning, the fin belt broken.
Jun 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint Ultima WF865 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
