The CMSOS is only a battery to store you're bios/mainboard settings.
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
The moment that you unplug the power and remove the battery for at least 10seconds, the mainboard will reset it self into the 'default-state'.
This can also be done by selecting 'reset to default settings' in bios screen.
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
To reset the CMOS the easiest way is, remove the motherboard
battery for ten minute then install it again. It will clear the CMOS. Then reset
the CMOS/BIOS setup, date/ time etc. Another way to clear CMOS is, reset the CMOS
Jumper in motherboard.
To detect your hard drive you can try to check by change the hard drive cables. Change the port in motherboard. Check the BIOS setup and reset it if need.
