Question about Paragon 8145-20 Defrost Timer
Wiring air defrost paragon 8145-00-oem
Correct wiring to tafco cooler unit
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: install and use Paragon 8145 defrost timer
try the uniline website
Posted on Feb 26, 2010
Keith Fournier
  • 308 Answers
SOURCE: how to wire the paragon defrost time with the
Your refrigeration circuit should be connected to terminal # 4, as this is the normally closed set of contacts, and the heaters should be powered from terminal # 3 as this is the normally open set of contacts. Hope this helps.
Posted on May 07, 2010
Anonymous
SOURCE: My coolers went down at my store. We installed a
how to wire a timer  8145-20  for a cooler
Posted on Jun 14, 2010
Anonymous
SOURCE: I have a paragon 8145-20 defrost timer. do you
Link below has wiring diagrams and wiring manuals for 240V 8145-20
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
I am not expert installing defrost timers.
According to information from Paragon, 8145 is for hot gas defrosting. 8140 series are time initiated, and pressure-or-temperature terminated.
Wiring diagram does not show compressor wired to timer.
The cycle works like this:
Timer is running but defrost is not switched ON.
Fan is ON.
Timer switches ON and activates defrost cycle.
Fan turns OFF. Hot gas valve turns ON for defrosting.
Cycle limit switch is temperature or pressure sensitive.
Cycle limit switch reaches trip point, timer switches OFF.
Hot gas valve turns OFF. Fan turns ON.
So fan is off during defrost cycle.
Hot gas valve turns ON when timer switches ON.
Timer is switched OFF by pressure-or-temperature limit switch.
Posted on Jan 20, 2011
Testimonial: "good info very helpful thank you"
Anonymous
SOURCE: What purpose does the solenoid
The solenoid switches timer OFF when temperature-or-pressure limit switch reaches trip point.
Paragon Model 632-00 Manual
Copy following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#632
632-00 is 120Volt defrost timer. Electric heat defrosting with fan delay.
Hot connects to terminal 4
Neutral to terminal 6.
One wire from Fan, compressor, heater each connect to terminal 6, and other wire connects to one of the other terminals depending on electric heat, hot gas, or water spray defrost
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 24, 2013 | Paragon Hardware & Accessories
Wiring a defrost timer to a heatcraft condensing unit
Which defrost timer do you have?
Do you have time or temperature termination?
What voltage are you working with?
Aug 17, 2012 | Paragon 8145-20 Defrost Timer
I'm looking for a control wiring diagram for this set up; The condenser is on the roof with a paragon 8145-20 in it. I want to control the defrost cycle of the walk in freezer that is downstairs. The...
Open following link to see wiring diagram and manual for Paragon defrost timers:
8145-20 is 240V time-initiated, pressure or temperature terminated, with back-up time termination.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Paragon 8145-20 Defrost Timer
I need trippers for parogon elect timer model # 4004-20
1) Paragon is no longer making timers or parts except defrost timers.
4004-20 240V 24-hour mechanical timer is not a defrost timer.
2) paragon 4000 series uses X2772 tripper.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
3) Some sites still show the X2772 tripper.
Some sellers are seriously overcharging for the tripper.
4) If you want to buy new timer: Intermatic cross-reference guide shows T-104 240V 24 hour is correct replacement timer
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
5) Amazon sells new T104 for 50$ which is cheaper than some folks are selling the paragon tripper:
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/tags-on-product/B000BQOX88
6) Change-over wiring from Paragon 4004-20 to T-104:
Hot wires from breakers. Paragon terminals 1 and 4. Intermatic terminals 1 and 3
Load wires. Paragon terminals 2 and 3. Intermatic terminals 2 and 4.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Feb 08, 2011 | Hardware & Accessories
Not keeping correct time
You posted under Paragon 4001-00 120Volt SPST timer
1) If timer is not keeping correct time, generally you need to buy new clock motor.
However Paragon is no longer making timers and parts, except for defrost timers.
4001-00 is not defrost timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
2) You probably need to replace timer
Intermatic cross reference shows T101 timer is correct replacement.
3) Amazon sells T101 for $43.
This price is a lot lower than trying to find somebody who has specific Paragon clock motor
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
4) Grainger and many other places sell T100 series replacement trippers and motors.
No worry about defunct product
5) Wiring for T101 appears below:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Cross-over wiring is as follows:
Paragon terminal 1 goes to T101 terminal 1
Paragon terminal 2 goes to T101 terminal 2
Paragon terminal 3 goes to T101 terminal A
Jan 27, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
I have a paragon 8145-20 defrost timer. do you wire the compressor to the timer? I cant seem to find a wiring diagram on how to wire this correctly
Fan is ON.
Dec 09, 2010 | Paragon 8145-20 Defrost Timer
8141-00-oem want come out of defrost mode?
You can contact Paragon (owned by Invensys Controls) Tech support at 800 445 8299 direct. When you call you will get an automated phone system. Navigate yourself to the defrost timer (not standard timers section) to get a tech rep.
Marty Walles is the most senior rep on these timers.
Apr 26, 2010 | Paragon 8145-20 Defrost Timer
Paragon 8145-20 Defrost Timer Logo
85 people viewed this question
Top Paragon Hardware & Accessories Experts
jdthefixer
Marvin
Marvin
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
