Question about Furniture
How to prolong the life of my mattress? - Furniture
Posted by joes on
  • varun Damaraju
    varun Damaraju Mar 09, 2017
    Use a Mattress cover, Clean Your Bedding Once a Week Or More, Use a Mattress Pad, Rotate Your Mattress Every Three Months and Take Extra Precautions For Pets
    Checkhttp://restolex.com/ for wide range of Luxury Latex Mattress, Spring, Coir & Foam Mattresses at Affordable Prices
Vishalsharma
    Habit-Forming:
    New Friend:
  • 94 Answers
Use a Mattress Cover.
Use a Mattress Pad
For more detailed information please visit: http://www.refreshmattress.com/product/back-support-mattress.html
Posted on Sep 07, 2019
Bobby Lewis
    Novelist:
  • 165 Answers
We've collected the top undercover ways to keep your bed in top shape. By following these sweet and simple steps, you can help protect your investment and make your mattress last longer.
Rule 1: Use a Mattress Protector
Perhaps the single most important thing anyone can do to make a mattress last longer is to use a water resistant or waterproof mattress protector. Even if you're a healthy adult who hasn't wet the bed in decades, spills and other unforeseen accidents can ruin an otherwise good bed.
Liquids and bodily fluids can degrade foams, leave nasty odors, and produce mold and mildew within mattress layers. Cleanup can be very difficult once a spill soaks below the surface, whereas a mattress protector makes clean up swift and easy.
You also sweat a significant amount each night, which is absorbed into your bed along with shedding skin cells, dust mites, and dust mite detritus. Keeping this out of your mattress reduces allergen buildup and keeps your sleep environment healthier.
Rule 2: Clean Your Bedding Regularly
People's preferences for frequency of washing sheets and bedding can vary widely, but most experts suggest washing sheets at least every two weeks or so. Bedding soaks in sweat, skin cells and lots of other things you'd probably rather not sleep with, so remind yourself to keep sheets clean. If you have dust allergies or skin irritations, consider washing sheets even more frequently.
Rule 3: Clean Your Mattress Regularly
Did you know you should clean your actual mattress, too? Every month or so, it's a good idea to strip your bed and vacuum the surface and seams to reduce dust and debris (even if you use a protector). Some cleaning experts recommend sprinkling baking soda on the mattress surface before vacuuming to absorb excess moisture and odors.
If your mattress cover is removable and washable, wash it as well. This is also a good time to inspect your mattress for any issues.
Rule 4: Regularly Rotate Your Bed
Rotate your bed regularly, especially the first couple of years. Every 2-3 months should be often enough to promote even wear and reduce impressions. Rotate your mattress even if the manufacturer says it's not necessary, as it will help extend your bed's lifespan.
Rule 5: Don't Eat In Bed
It's tempting to grab breakfast in bed or snack while watching movies, but it's really a good idea to keep food off the bed. Crumbs can find their way into sheets and mattress layers, attracting nasties, while liquids can spill and cause problems as well.
Rule 6: Get Pets Their Own Beds
It may be comforting to have Fido to snuggle, but pets bring a whole new set of problems with them to bed. For one, they sweat, slobber, and shed hair and dander, all of which you'll be sleeping with. Pets are also prone to accidents, which can ruin a good mattress.
Animals that go outdoors can track bugs and mites indoors as well, so it's better for everyone if they have their own designated beds to snuggle up in.
Rule 7: Be Aware of Bed Bugs
Bed bugs can immediately turn a decent bed into a hazard zone. Be vigilant when you go to hotels or sleep away from home, as bed bugs are prolific hitchhikers and they can easily become your problem.
If you live in a bed bug prone area, consider using a bed bug-proof mattress encasement. These zippered covers fully encase the bed and prevent bugs from getting inside.
Rule 8: Ensure Your Mattress is Supported
Your mattress is designed to support you, but it also needs to be supported to provide long lasting comfort. Inspect your bed frame and foundation/box springs every couple of years to make sure they are in good shape and providing a solid foundation for your mattress.
Boxsprings that are saggy and worn out, wood slats that are weak or too far apart, or a broken frame can all contribute to quicker wear and reduce your comfort.
To know more, please go through the link below -
Unbiased Lull Mattress Review The Truth About Mattress 2017
Posted on May 09, 2017
Jack Flaming
    New Friend:
  • 16 Answers
Use of a mattress protector is a good way to protect the mattress and so increasing the life of the mattress. Mattress Protectors protect the mattress from dust, dirt, mites and water and also add extra comfort to the mattress.
Posted on Aug 30, 2012
phil
    New Friend:
  • 27 Answers
In order to prolong the life of your mattress you should try and keep the following.
1) Using a mattress pad or a protective cover will help you avoid stains.
2) Use a good and quality bed frame
3) Try to avoid jumping or standing on the edge of your mattress in order to eliminate bends
Posted on Jul 18, 2012
Why do I need a mattress protector?
The first reason to have a mattress protector is to keep your bed clean. Our bodies are not as clean as we think even though we take bath every day. we perspire at night, our skin produces oil while some of us put on makeup. All this can get into the mattress and once it gets in, we cannot remove it. A mattress protector will not let this happen.
Secondly, we all love to keep our mattress new. we do not want it to shorten the life of the mattress. Dust mites consume dead skin cells and the dead skin cells will remain on your mattress if you do not use a mattress protector.
http://bestmattress.in/top-10-mattress-protectors-in-india/
Feb 08, 2016 | Furniture
Tip
How to care for your mattress
Although mattresses come with a warranty, this does not mean that you should not care for it properly. The following is a list of ways in which you can further the life of your mattress and keep it in great condition.
Ensure proper installation
Make sure to let your mattress breathe - when you take a vacation, do not leave sheets on your bed; try stripping the bed twice a week and leaving it without sheets until the time you are going to bed
Do not jump on the bed - keep children from jumping on your mattress
Keep your bed from sagging by using a supportive bed frame
Use a mattress pad to absorb moisture/perspiration that can be easily removed and washed
To help minimize wear and maximize comfort make sure to rotate your mattress every two weeks during the first three months after purchase and every two months after that
Here is a great guide on how to properly rotate you mattress:
http://www.wikihow.com/Rotate-a-Mattress
on Aug 28, 2012 | Furniture
My laptop battery only charges to 70% now, but my fault really: i remember a popup window asked me whether i wanted this option, since it would prolong my battery life. without thinking, i agreed to this....
It really prolongs your battery life. I would recommend to keep it this way, while I don't know where to find the menu option to change it back.
Sep 17, 2013 | Dell Latitude C640 Notebook
I just bought a new mattress. Should I just throw the old one away?
You should donate it. You can prolong the life of your mattress by donating it to charity. You should visit this website DonationTown.org to organize a pick-up and delivery.
Jul 25, 2012 | Furniture
How often should I turn/rotate my memory foam mattress?
Memory foam mattresses should not be flipped at all - they only have memory foam on one side.
How often should I rotate my mattress and is it necessary?
Mattresses should be rotated and flipped at least twice a year to achieve a longer life span. A tip my friend gave me to help remember was: spring spin, fall flip (meaning in spring time spin your mattress and during the fall flip it). I have found a great guide to rotating your mattress that I think you will find helpful.
LG AC Split Compressor Condensers burn out ( malfunction). We have 11 units in the house, installed less than a year. Temperature in this year summer was extremely hot in Saudi Arabai, 50-55...
you can not put a life span on a capacitor but for your condenser/maintenance is the main thing to prolong life you your unit they must be cleaned and tuned up regularly
Sep 29, 2010 | LG LSC121PMA Split System Air Conditioner
Furniture Logo
3,663 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
