How to Replace a Whirlpool Washing Machine Drain Pump
To Replace Whirlpool Washing Machine Drain Pump follow this link to watch an instructional video. http://youtu.be/zyek3zhD9CM
SOURCE: Whirlpool LSR8233JQO Washing Machine
My idea is to oil mine and I came on here to find info on how to remove the back, it's impossible!
SOURCE: Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
