How to pump up a basketball
To watch an instructional video follow this link http://youtu.be/WnU8XSEhfCU or read the instructions below.
To pump up your basketball you will need a ball needle and a hand pump. Insert needle and pump the ball to the specs listed below.According to NBA rules, the pressure inside a basketball must be between 7.5 and 8.5 lbs. You can use this as a guide for your own basketball pressure. Another simple test is to drop the ball from shoulder height. It should bounce to a height approximately even with your hips. When inflating the ball, use a small pump and pressure gauge. Avoid using high pressure pumps made for cars and motorcycle tires, which can easily over-inflate and damage your ball.
Testimonial: "Thank you, Great video"
Get a ball needle and air pump and there you go!
Here is a complete guide on how to pump a basketball with a needle and without a needle. https://outdoorballpro.com/how-to-inflate-a-basketball/
If I choose sports for betting, then I will definitely focus on basketball. I really like this sport, so I didn't doubt it at all. In addition, the community for bettorshttps://takebet.co.uk/ always has a lot of basketball tips and predictions, which greatly simplifies the process of betting. In general, I'm glad that I discovered the opportunity to earn on bets.
