Philips 27PT5445 27" TV Logo
Question about Philips 27PT5445 27" TV
Philips tv model 29pt6961/69R with inbuilt DVD, there is an error message with numbers looks like this HRS : 105E SWID A10ADT-1.5 ERR: 7 0 0 0 0 0 0 OPT: 94 239 255 204 0 0 0 0 CLEAR ERROR > OPTIONS > etc ... I lost the remote and it cant go away even when I press the two volumes together it takes me to the PICTURE > SOUNDS > menus. Totally lost! my email: [email protected]
Posted by charlzlia on
5 Related Answers
Anonymous
  • 556 Answers
SOURCE: philips model ptv915 model # 60P8341a
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Posted on Oct 19, 2007
Anonymous
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
Anonymous
  • 476 Answers
SOURCE: philips tv with autolock
Check out page 14 of the manual.
If you don't have the manual click here to download:
https://www.p4c.philips.com/files/2/27ps55s/27ps55s_dfu_aen.pdf
Posted on Apr 03, 2008
SOURCE: philips 27ps55 s321 tv remote problem
bought a new universal remote control of phillips
Posted on Jul 05, 2009
KISHORE DESHPANDE
  • 64 Answers
SOURCE: Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Posted on Jul 12, 2009
Philips dvd home theather,i didn't get a users manual,i can't get the sound to come out with the tv,it will owrk with the radio. lloyd
I will guide you through it.
Just to clarify, When you say sound out with the tv, which are you referring to:
1. DVD built into to the theatre
2. Pay TV
3. Analogue TV ( or digital TV with inbuilt set top box)
4.Digital TV with a separate set top box
Please indicate which one.
TV: ther should be several set of three RCA Sockets on the back of the tv. Look for the red, whit and yellow Phono sockets. do you have these colours and are any of them labelled TV Out or output?
Philips System: Look for an analogue in, Aux IN, or any other unused RCA (Phono) Sockets ( They MUST be red or white!)
Take a set of red and white RCA leads plug them into the OUT set on the TV, and The "INput" set on the Home theatre, select that input on the theatre and your off and racing!
Please clarify first though!
1helpful
Need Codes
EMERSON TV CODES
0 1 5 4 ,0 2 3 6 ,0 4 6 3 ,0 1 8 0 ,0 1 7 8 ,0 1 7 9 ,
0 0 1 9 ,0 6 2 3 ,0 6 2 4 ,0 1 7 7 ,0 1 8 5 ,0 2 8 2 ,
0 0 3 9 ,0 2 8 0 ,0 0 3 8
SONY DVD
0533
Please rate our help to keep the FREE service online++++Thanks for usiong Fixya
5helpful
3answers
Philips 105E
I have philips monitor 107E there is a supply problem i want to repair it. I need circiut diagram for repair.
2answers
60PP9352-17-Philips Magnavox Problem-PLEASE HELP! Hello, We are going to as explanatory as possible... Model: Philips-Magnavox (60PP9352-17 / DPTV310) Problem: HDTV turns on and you can watch it, however,...
Start with replacing Both of your convergence ICs they are big black ics STK will have Part # on them this should solve your problems, Parts call 1-800-223-3205 www.electronix.com You can also order on CD Service Manual #7621 and 7541 Call 1-800-221-5681. Thank You and Have A Nice Day.
Error light
There is an error code that flashes on front of TV. which is in this case an error 7 which is power related. Also there is a gree LED on the power supply that will flash an error code also. If u look on the power supply U will see a list of numbers 1-13 which list the error codes and what they mean.Usually if it flashes 1-9 its usually cheaper to just buy another TV. because the Power supply , Y-main, X-main will probably run $300 plus core charge.
Error message/Switching off
Hi.
What is the model number on the rear of set & chassis number if it has one.
109helpful
12answers
In need of codes for philips universal remote CL034
The codes to Sony TV's Are:
0414
0902
0801
0708
0639
Good Luck
This is for model number 3L034
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
