Question about Maytag MAV6457 Top Load Washer
Maytag agitator will not turn
I have a 2004 MAV6457AWW Maytag washing machine. Spin cycle works great, no crazy noise or anything. However when the agitator runs on wash and rinse cycle it will not turn with clothes in it. Empty it turns for the most part. It is also making a grinding noise. Like a stripped bolt maybe? Please help!
Posted by admaynard on
Semei Farah
    New Friend:
  • 32 Answers
Sounds of a loose motor or need brushes replacement.
Posted on Jan 13, 2018
5 Related Answers
Terry Schneider
  • 177 Answers
SOURCE: I own a Maytag Performa
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Posted on Jul 12, 2008
Robert Siegel
  • 36 Answers
SOURCE: Washing machine won't agitate
it sounds like the transmission is shot. Not knowing the cost of parts if you can replace the transmission yourself then yes it could be worth fixing however if you can't do the job yourself adding cost of parts and labor it may not be worth it
Posted on Jan 01, 2009
appldoctom
Thomas Malailua
  • 311 Answers
SOURCE: Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Posted on Jan 03, 2009
Mike Inman
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
Anonymous
  • 89 Answers
SOURCE: Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
Posted on May 28, 2009
I have a Maytag Ensignia MAV6457AWW washing machine that has a noise in the lower end of the agitator (which sounds like the transmission area) It is a rattling sound like something has broken. It is...
In this case it seems that the main bearings on the shaft is a suspect. However if you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Oct 04, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
Maytag 2005 washing machine top load model number PAVT454EWW makes a loud grating noise when it seems to be in a agitation cycle, and the motor is running and the belt is working, but the agitator is not...
HI thanks for the question. yes it sounds like the tranny. Maytag has 5 yr warranty on the tranny. have it replaced thanks the appliance doc. please rate my answer.
Oct 07, 2008 | Washing Machines
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Jun 02, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag MAV6457 Top Load Washer Logo
257 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
Michael Thomas
Michael Thomas
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
