Question about Kodak EasyShare C340 Digital Camera
My c340 EasyShare camera won't turn on
It was working fine one day the next it wouldn't work at all the button where it turns on feels loose.
Posted by Charlotte Hilliard on
5 Related Answers
leepania
Pania Lee
  • 1099 Answers
SOURCE: My kodak easyshare V1003 camera will not turn on.
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 09, 2009
Anonymous
SOURCE: GREEN LIGHT TURNS TO RED & CAMERA WON'T WORK
send it back and purchase a different camera
Posted on Jun 29, 2008
Anonymous
SOURCE: Kodak EasyShare C613 turns off when connected to PC
The camera is supposed to go blank when connected to computer.
I hit the "share" button and can then download photos, even though screen is still blank.
Posted on May 27, 2009
Anonymous
SOURCE: camera turns off immediately when I turn it on.
I had this problem as well. After spending an hour with a service representative from Kodak, I was told that in order to fix it, it would cost me $60 + $10.95 shipping + applicable state sales tax. I was frustrated when I realized that I may as well just buy a new camera. I then proceeded to gently poke/prod/slam the camera against my hand, but nothing changed. Then, in a moment of inspiration, I turned it on and gently held the outside of the lens as it turned off. When I tried to turn my camera back on, the problem (whatever it was) was fixed!
Posted on Apr 21, 2010
Anonymous
  • 1234 Answers
SOURCE: I have a Kodak Easyshare M1033. When my camera
HELLO SIR
turn it on , Press Reset Buttonù
turn it off , still pressing The switch on button 10 seconds
It works for me
Posted on Aug 29, 2010
My Trane XE1100 air conditioner won't start at all, worked fine one day and the next it wouldn't come on
check breakers in breaker panel,I need more info.is it blowing air inside
Jul 01, 2013 | Heating & Cooling
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
My c340 turns on and than right off. With new batterys, I get 4 pictures than it turns off.
you might be using Alchaline batteries. This kind is not strong enough to run the camera.
Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Jan 23, 2010 | Kodak EasyShare C340 Digital Camera
Kodak easyshare c340 wont turn on
My EasyShare was doing the same thing your post describes, which is how I came to be at this website. I tried the one suggestion of turning on camera (I did so to the 'Auto' setting), then pressing the |O|/i button, which is the button below the 'delete' and above 'menu' next to the screen. That didn't work for me. I then tried the suggestion with the other modes on the power dial, no luck.
I then, from the off position, turned the dial the other way, to the 'favorites' icon, and it worked! I didn't have a memory card in at the time, so it made a noise almost like saying "uh-oh", with the message 'no images in favorites'. I then turned it off, then turned it to 'auto' again, good to go! The lens opened, green light remained on in all modes.
If this helps even one person, I'm glad.
Dec 06, 2008 | Kodak EasyShare C340 Digital Camera
My c340 is unable to initialize photo transfer via usb once connected to the computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 11, 2007 | Kodak EasyShare C340 Digital Camera
Problem transfering pictures to computer
Oct 19, 2006 | Kodak EasyShare C340 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
140 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
