Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Crafstman garage door opener 39.53671 won't open
Garage door opener doesn't open with wall button or remotes and light bulb does not come on. Unit clicks twice and LED light flashes 5 times.
Posted by abenningfiel on
Don Maggard
    President:
  • 3,197 Answers
Is the door stuck in the open position?
Posted on Jul 18, 2012
5 Related Answers
myob247
Georgia B
  • 1342 Answers
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
Anonymous
SOURCE: sears craftsman 1/2 hp garage door troubleshooting
I've got a similar problem. The green light is flashing on the unit. I can here a click when I try either the remote or wall mount switch, but no movement.
FWIW our wall switch has a lock and a light switch and I can't get the light to go on either.
The door moves freely when disconnected from the opener.
My gut tells me the logic board is fried. What I'd really like to find is some sort of trouble shooting guide - Is anyone aware of any trouble shooting information on these lifts?
Posted on Aug 24, 2008
Anonymous
SOURCE: flashing green light on Sears garage door wall opener HBW0777 1/2
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
Posted on Dec 13, 2008
Anonymous
  • 244 Answers
SOURCE: Craftsman Garage Opener Clicks only and LED blinking 5 times
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Posted on Feb 12, 2009
Don Maggard
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
Posted on May 17, 2009
Remote won't work but keyless entry does on garage door
If the light in the wall control is flashing press and hold the lock button for 3 seconds. Your remote should now work.
Jul 23, 2012 | Sears Craftsman LiftMaster Chamberlain...
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens sometimes with remotes< and exterior keypad. always works with wall mount button.
Check the light bulbs in the opener. Newer fluorescent or LED bulbs can generate enough radio frequency interference that the normal signal levels from the remote will be inadequate.
Of course, make sure the remote batteries are fresh.
Sep 04, 2011 | liftmaster Garage Door 1/2 Hp
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
How do I program a remote garage door opener for a Crafstman 139.53615SR?
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Hold down the button on the remote while you press and release the smart/learn button. If everything is working and it is the right remote for the opener it will be programmed.
Aug 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote works only when Garage Door Opener light is OFF
I discovered that certain light bulbs interfere with the remote sensors. Harware stores have clear vibration reisistant bulbs for garage doors, try them instead. After spending money on a new remote, resetting remotes, and weeks of aggravation...poof.....i found it was the type of bulb I was using. Used a clear bulb and the problem went away. Hope this helps.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
429 people viewed this question
Top Sears Building Materials Experts
Mike
Terry Smith
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
