Cisco 7960 IP Phone Logo
Derek Rippe Posted on Jul 17, 2012
Cisco 7960 turns it self off
I purchased a working cisco 7960. I tried to plug it into the internet with an ethernet cable and when i do this it turns itself off. What should I do?
Bob Fells
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jul 31, 2012
Bob Fells
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
10602
Points
24
Do you have a power block for the phone or are you getting power from a POE switch via cat5 cable?
How do you know you purchased a working phone? When was the last time the phone worked properly?
Any other information you can supply about your VoIp setup would help us troubleshoot the power issue with your phone.
1 Related Answer
nkrcs
Nick Kail
  • 94 Answers
  • Posted on Jul 23, 2010
SOURCE: no dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Desktop pc windows 7 sp 1 wired cisco dpc 3008 no additional devices random connections
I would first get a new Ethernet cable and try it. If that doesn't fix it, call your cable company and have them do a diagnostic from their end. They can tell if it is their equipment or not. It their modem is OK, and the Ethernet cable is OK, then your LAN (Ethernet) card is either going bad, or possibly not completely inserted in the socket. To check: turn off and unplug your PC. Take the side off, look where the Ethernet cable goes into your computer. If it is on the motherboard, you may want to get a LAN card and use it instead of the onboard. If the cable goes into a card plugged into one of the slots, make sure it is fully inserted. If it is, you may want to get a new card.
My cisco ip phone 7960 is stuck in boot up mode after performing the soft reboot. i press 123456789*0#
You can try a couple of things: Unplug the power cable from the phone, hold dows the # key, and then plug the power cable in again. The phone begins its power up cycle. Release the # key after the Speaker button is no longer lit. You should see the following message on the phone: "Reset key sequence detected" Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
Or to perform a full reset: Press **#** to reset the Cisco IP Phone 7960
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
How can I upgrade my frimware on the Cisco 7960, it is a 3 and needs to be 7?
Best and easiest way is to plug it into a newer callmanager. The firmware will be upgraded regardless of wether or not it is able to register.
1helpful
No dial tone on cisco 504G phone
Ethernet LAN light goes off after few seconds
when the booting all light are turn on that's normal , after few second ethernet light momently on because ethernet chip internaly loop and check the ethernet chip that why you seen the ethernet light momently on after that ethernet should lit on if you connect router ethernet link to pc or ethernet switch.
pls check the ethernet cable , if you connect to ethernet switch pls try with cross over cable and if you connected to pc pls check duplex to auto or forced to 100 Mbps
I have a cisco router linksys. I connect internet cable to it in ethernet port. Neither by wire not by wireless I can connect my laptop. The connection comes as only local
If you can plug the cable that you have ran into your router into your computer directly and it works, then you can plug the router back in. Then connect the computer to the router via cable and unplug the router for about 15 seconds and plug it back in. If you connect the computer by cable directly and it doesn't work, then try unplugging your router for about 15 seconds and then plugging it in. I have found many networking items that need to be reset whenever a network cable is plugged in when the device is powered on.
7906G Home VOIP installation Problem
Then you need power adapter for Cisco 7960 IP phone ( -40V DC).
Cisco phones work best with Cisco, and sometimes ONLY Cisco switches.
One question which voice gateway you will use for your 7960 VoIP phone calls to go through ?
(AT&T probably supports only their IP Phones with special and usually hidden settings from end user)
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
