I am sell nokia x3 in aug 2011.,,i have warranty upto aug 3 2012..now..in time the screen are totally white....then i am going 2 nokia care...they are saying ....some water drop were in side the phone...no warranty in this...but..i am not satisfied that resoan ..because my phone in completly perfect in last minitue ..does not near in water and any other foolish reasons....please correct the phone
Hi you could not say that there should be no water>> but it can occur because due to high humidity water can easily get inside.Anyway,only lodged of water is not the reason the main strip (pata) frequently damage/break so if all the other function are working perfectly change the strip.Or sometimes the strip of the LCD also damage easily because this very parts had been inserted by bending the lcd strip.It will cost you $2-$3.No matter what it is under warranty or not.But it is up to your wish.Good luck.Thanks for visiting fixya
SOURCE: nokia 6085 has a blue screen
try to replace flex,,, if no luck replace also crystal ic beside the connector....
SOURCE: when ever i try to
Your phone has a corrupted program. Send your phone to the Nokia Care Center near you and have them upgrade the firmware of your phone. The problem will be resolved.
NOTE: Please be informed that all files or data that are saved in the phone's internal built in memory will be erased.
Thank you and good luck!
SOURCE: my nokia x3 wont start
Remove the battery and the SD memory card, check the card for corrupt/virus infected files that have corrupted the software. Now have it scanned on your PC and remove/format the card.
Reset to the phone and check , if the fault comes back then the software must be installed on the phone. have this done at the Nokia care/support center.
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link X3 file or Nokia flash file and install it to C / programme files/pheonix..after finished this installation open pheonix Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck.If you could not do please contact me.
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link X3 file and install it to C / programme files/pheonix..after finished this installation open pheonix Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
