Question about Janome Mini Compact
I need a manual for a Janome 120 compact sewing machine
I don't know if the Janome Mini Compact is the same model as mine (it looks slightly different). Mine is a compact version, however- but it has a 120 on the front (and on the model tag- it says model;- 120 as well). I purchased it second hand of someone- but they didn't have the instruction manual for it. I just want to be sure I don't 'thread it up wrong' or something. I'm really hoping someone might be able to point me in the right direction! Thanks :o) Garlee. B
Posted by Garienne Blochowiak on
5 Related Answers
Anonymous
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
lavon82931
La Von Beckstead
  • 17 Answers
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Posted on Jan 25, 2009
Anonymous
SOURCE: How to thread sewing machine Janome model 372
how to thread a janome model 372
Posted on Dec 27, 2009
Anonymous
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
Anonymous
  • 6 Answers
SOURCE: Can I use a twin needle on my Janome MW3018?
Twin needles can be used on any machine. Just make sure you use the correct presser foot......one that allows both needles to work without hitting the foot. Also.........you cannot zig-zag or use any other fancy stitch with a twin needle.......it is strictly for straight sewing. You have to use 2 spools of thread .....thread your machine with both threads as if they were one thread but separate the threads when you get to the needle. There is no change to the bobbin. Happy sewing. I can't be bothered to go to all this trouble so I just sew 2 rows to get the same look. Ofcourse you have to be very good at sewing perfectly straight seams doing it this way. Try both methods on a scrap and see which method you prefer.
Posted on Dec 21, 2010
My Janome mini compact will not sew through a double layer of flannel. I have tried changing the tension.
sometime the needle & thread are not compatable--try this & see if it work for you
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Is there somewhere I can order a replacement part for a Janome Sew Mini sewing machine? I need the little clear door that covers the bobbin compartment.
Try www.sewingpartsonline.com and put in Janome then your model number, they have all kinds of parts for sale. They may have your part or call Janome at 1-800-631-0183
Type of needle for janome mini compact
Hi
Ask Jan on the Janome website.
http://www.janome.com/index.cfm/LearningCenter/AskJan
Or try on the forums there.
http://www.janome.com/fusetalk/forum/
I would imagine that Janome universal needles would be fine for this machine.
Thicker needles are required for sewing thicker fabrics.
I need a user's manual for my Sew Mini model. I've misplaced mine.
here are some websites to try
1.(pdf) manualsonline.com
2.sewusa.com
3.sewingmachinesplus.com
4.homeapplaince.manualsonline.com
Lost ac adapter
Have you tried a Radio Shack?? They have all kinds of adapters.
9helpful
3answers
Owners manual for sewing machine Janome JF1004
Accessories for the Janome Mini Sew
Almost all of the Janome feet are interchangeable. Only a very few of their higher end electronic machines have special feet. So, if you ask for Janome feet, in general the stores give you the general purpose feet that work on most mechanical Janomes, such as Jem Gold, Decor, etc. Hope this helps!
1helpful
Have no instructions for janome sew mini
Have a look at this website, if you machine is not listed email them and they will help, it will cost for a manual but very little is free these days.
www.sewusa.com
Singer Model 324
go to this site. it is the singer sewing machine company. they have the instruction manual for your 324 featherweight Plus - they charge $15 for the manual. http://www.singerco.com/accessories/manuals.html
Janome Mini Compact Logo
Top Janome Sewing Machines Experts
Joseph Hoffmann
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
