The lighter does not work and I need to use my GPS!!!!
SOURCE: How do I fix my cigarette lighter in my 2000
There is a fuse located in the "underhood junction block." The fuse is a 20A fuse, and is in cavity number 34 -- called the "AUX PWR/CIGAR" cavity.
The underhood junction block is on the driver's side of the engine compartment. There may even be some spare fuses for you to use in there.
SOURCE: Which fuse is the cigarette lighter on a pontiac grand am 2001
The fuse is located in the fuse box under the hood, (on the driver's side)
SOURCE: Where is the cigarette lighter fuse for a 2002
In the fuse box under the hood, marked AUX PWR/CIGAR..... 20 amps.
SOURCE: 2005 pontiac aztek cigarette lighter fuse...
usually the cig lighter fuse is the same as the horn.
SOURCE: 2003 pontiac grand am cigarette lighter does not work
no, are you checking the lighter with the ignition in the run position?
