Question about Calvin Klein K7111
Replacing battery calvin klain k7121 watch
How do i remove back plate
1 Related Answer
Kimi
Kimi
  • 277 Answers
SOURCE: Calvin Klein K7111 brown watch strap
try here: http://www.a1watchbands.com/ for example: http://www.a1watchbands.com/product_details.php?search=&id=712 or try on ebay, for example: http://search.stores.ebay.ie/calvin-klein-strap_Watch-Parts-Accessories_W0QQcatrefZC6QQsacatZ10324
Posted on Aug 17, 2006
Battery replacement
Hi.
Battery replacement is done removing the back plate. The back plate is uncrewed clasping it with a special tools and rotating anti-clockwise. In absence of the special tool a common pair of tweezers will do the job.
Once the back plate is off, extreme care must be taken with the rubber seal, running around the edge of the case opening. This is very delicate, and damaging or kinking the seal may result in the watch loosing its water proof capacity. For this reason battery replacement is better done at the shop.
Here casio page for this model:AMW320R-
Sep 28, 2010 | Casio AMW320R 1EV Casual Sports Watch
How to change battery
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
    Battery replacement procedure for Casio 901 DW-5600?
    hi, if the back plate on the watch the part that is against your wrist has four screws holding the silver back plate onto the actual watch then you need to undo these four screw, once undone you lift the back plate off and then this gives you access to the battery, the screws are small philips (cross head screw) so you will need a small screw driver, their is also a little bracket that holds the battery in place you can either push this over to allow the battery out or undo the small screw that holds this bracket in place this will then allow the battery to fall out,
    If their are no screws in the back plate then all you need to do is get a very fine flat head screwdriver and look around the edge of the back plate and you should see a little bit on one of the edges that allows you to put a screwdriver into to allow you to lever the back plate off if it has no screws then its just a push fit so just pry the back off and this will give you access to the battery then like above the battery will be held in place by small bracket undo this then remove the battery.
    when fitting the new battery make sure you dont touch the top and bottom of the battery as this will flatten it really quick so just push it in place then refit the bracket then either push the back plate back on or screw it back on depending on the type of back plate once this is done you watch will be working again
    Aug 14, 2010 | Casio DW-5600E-1VCT Wrist Watch
    How to replace the battery for ck k22271
    mcdevito75 here, With battery change only once a year, and the tools needed, the BEST BET is to look for a small watch repair shop in your area for a new battery.
    Jul 13, 2010 | Calvin Klein K2227175 Watch
    How can I find out if my CK K30331 watch is fake? I tried to google it but i couldn't find any useful information. It also stopped working and the glass is blurry/foggy inside.
    mcdevito75 here, Best Bet, Calvin Klien a nice watch, Find a small watch repair shop in your area and they can tell if it"s real or fake., Chances are it"s a real Calvin Klien.
    Jun 29, 2010 | Calvin Klein Bold watch #K3031130 Watch...
    Aug 17, 2006 | Calvin Klein K7111
    Calvin Klein K7111 Logo
    107 people viewed this question
    Top Calvin Klein Watches Experts
    Bruce Robin
    Janelle Schoonover
    Janelle Schoonover
    STEVE SPAM REMOVER
    Are you a Calvin Klein Watch Expert? Answer questions, earn points and help others
