Ezonics VistaCAM Freedom LX Digital Camera Logo
Posted on Sep 27, 2017
I have an Exonics LX Freedom camera and I have lost the instructions for using it. Do you have any idea of where I can get new instructions. I am 69, so my memory is not too good. If possible, I would them FAX'd to 661-940-0448 and e-mailed to [email protected]. Thanks, Joan
How do you set high resolution on the camera before taking the photos? I have lost my manual. Can I also down load the overall guide?
You can download the manual (and more) from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd940_is#BrochuresAndManuals
Follow the instructions on page 69.
I lost my instruction booklet for my new coolpix L20, so i have no idea how to use it a t all
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps you. Thanks for using FixYa.
I need instructions for minolta freedom zoom 70 exI want to know what macro does.
Hi. As a pro photographer, I can tell you what 'macro' does on all cameras or lenses. 'Macro' focusing is for focusing on close objects, say an inch or two from the lens to a couple of feet. It is for closeup shots, say ants, or a fly, or someone's eye, raindrops on glass, etc. Try it out sitting on a patterned countertop or table or tablecloth to give you an idea, focusing far away and up close.
As far as the manual, there doesn't seem to be anything on the official site unfortunately. Good luck and have fun.
http://gi.konicaminolta.us/index.asp
1helpful
CAN NOT GET FILM OUT
have you tried manually rewind ... there must be a button provided at the bottom ..... if not then get it manually removed by a photo shop ...as you wont b having a darkroom and you might ruin the pictures.......
3helpful
Instructions for a Minolta Freedom Zoom 70 C Camera
Hi - You can download the manual by clicking the link underlined in blue below:
Freedom Zoom 70 C
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Instruction booklet or Manual
the camera will not turn on even though I have inserted new batteries
25helpful
5answers
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Top Ezonics Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Ezonics Camera Expert? Answer questions, earn points and help others
