Since i cleaned my register with CCleaner, i have the message "The feature you are trying to use is on a network resource that is unavailable. ... Click OK to try again, or enter an alternate path to a folder containing the installation package "hpproductassistant.msi" in the box below" How do i need to fix this? Thx!
SOURCE: Missing "copy.msi" file
You will have to download the whole program from HP.
Here is the website -
For XP: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-42045-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=1153481
or for Vista: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47461-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=1153481
These are 300 mb and once you have them save them to desktop, or to the hardrive in a temp file. Run it and it will re-install the program.
What probably happened is you loaded a program which overwrote something in one of the files, or you removed a program that took something important with it. Believe me it happens all the time, so don't feel bad.
SOURCE: when i reboot i get a message that says The
You have a printer attached to computer A that is shared with computer B. You are on computer B with something in the print Que but computer A is not turned on OR - there is a problem with your network communications.
Turn on computer A; clear your Que on computer B; resolve (reboot everything that makes up the network) the communications proble.
May I suggest you get the free to cownload and evaluate netwokk manager Network Magic. Read the deal while there.
Network Magic will aid you in all network management, including security, issues. You may like it enough to spring for the for couple $ to use it unlimited. Get it here ... www.purenetworks.com/download/
I trust I have been of some service this Saturday afternoon when I should be raking leaves outside.
If I misunderstood your question, or mis-interpreted, please post a comment to this question outlining your particulars so I can try again.
Thanks for your interest in FixYa.com
Please vote
Positive comments are always welcome
a
SOURCE: I have a continuous problem
You are right about the windows installer, yes it could cause this issue, but let's make sure it could be re-installed/re-updated or not.
First of all, uninstall/Remove all Hp softwares and drivers from your computer.
You can use this utility to completely uninstall (Click Here).
Have you tried updating the Windows? If not, do so and check whether Windows Installer is included in the Available Updates or not. You can run the Windows Update from Internet Explorer. Open Internet Explorer, click "Tools" and then "Windows Update", follow the instructions on the page and select "custom" in other words, don't select "express".
If you don't see any Windows Installer in the updates lists, download this and install (Click Here). [I hope you xp sp3 is 32-bit version], download and install the Windows Installer.
Now download the HP software and Printer Driver from here. Open the link, download both the drivers and install. After that restart your computer, download the "Updates" and install it.
Also, download and install the "Hp Print Diagnostic utility" [All these are on the download page], click the download sub-sections to expand and download them.
Hopefully, everything should go without any problem.
Once everything is installed, restart your computer.
If you need further help, let me know.
Good Luck.
Thanks for using FixYa.
