Maytag Advanced Cooking System, Model MES5770AAQ, S/N16393304ZaZB F1 - This code appears when an oven reaches about 250 degrees. It goes away when I press "Cancel" button and oven reaches about 350-400 degrees with several resets. After reaching that temperature it stops heating and cannot be reset until temperature drops to about 75-100 degrees. F1 also appears when cooktop burners (either of them) are in use. Burners are working fine even with this code displayed. Only error code and bips are present and temporarily go away when press "Cancel" button. This problem appeared after the cooktop had been replaced due to a broken glass. Second cooktop was replaced too, but same F1 problem still persists. Pls. help to resolve this problem ,My email address is [email protected]
SOURCE: unable to use oven
arkist, sounds like you are in the sabbath mode. Press and hold the clock pad for 3 to 5 seconds. See if it comes back to life...Catriver..post back.
SOURCE: I have a Maytag Advanced Cooking System Model
HI. This will occur when there is a fault present within the main control board, or touch pad assembly. use the procedure below to determine where the actual damage is located.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Caution: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
SOURCE: Oven takes up to 45 minutes to reach temperature
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
