Just got one of these cameras from a charity shop and after only a short use same problem.
Try connecting camera to PC as an external drive and delete (all) files..... This, too, may not work, in which case reformat the whole drive representing the camera - quick format will probably do.
Once you take a photo the directory path: DCIM/100IMAGE will be recreated.
I'd recommend reformatting quite regularly - after each time you download the photos off the camera.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Possible that the switch on micro switch which triggers from the slide cover is damaged and so does not switch on. You might need to remvoe to find this fault and replace the switch, set the alignment once again or refix the switch .
The 500D doesn't have any internal memory for picture taking. It won't store any pictures unless you insert an SD card in the slot just above the battery on the right side of the camera (when you are looking at the screen)
E1532 signifies # events that have occurred , not an error...you probably have something like P0198/E1534...go into setup until delete images NO;press select;up down arrows to get flashing YES;select..then scroll to delete events NO;press select up or down, select.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
