Question about LuxPro PSP711TS Touch Screen Programmable Thermostat
How to reset filter indicator on luxpro psp511lca
I need to reset the change filter light
Posted by Arturo Meza on
Ann Bear
    New Friend:
  • 12 Answers
RESET FILTER COUNTEROnce you have replaced your filter, the filter life counter is reset back to its fullamount remaining value by turning the dial to AIR FILTER and pressing the UPand DOWN buttons together at the same time. NOTE: The counter is also reset bychanging the filter setting value, as described above, to a different number ofdays.
Posted on Apr 10, 2013
  • Sonjah Marshall
    Sonjah Marshall Dec 28, 2013
    How do I reset the filter setting value
How do I deleate the change filter light?
My model is the psp511lca but it may be the same type of reset. I have a dial I turn to the "change filter" option and then press the up and down temperature buttons simultaneously and hold for a few seconds. When you turn the dial back to "run" the change filter light on the display is gone.
Sep 12, 2014 | LuxPro PSP711TS Touch Screen Programmable...
What filter is in the thermostat
When the change filter indicator comes on, it is referring to the filter in your furnace. The thermostat itself does not have a filter.
May 08, 2014 | LuxPro PSP711TS Touch Screen Programmable...
No hot water
This indicates a reduced supply of water to the heater. Check water flow through the tap has not been reduced If so, check filter area
Apr 17, 2014 | Takagi T K3 OS P OnDemand WaterHeat
Reset air psp511lca
To reset the air filter indicator:
1. Open up the control panel and turn the dial to "Air Filter"
2. Press the temperature up and down buttons simultaneously
3. Turn the dial back to "Run"
If you forget these instructions, you can find them in the owner's manual. You can download the manual here:
http://www.luxproproducts.com/pdfs/PSP511LCa_NL_ENG_Manual1.pdf
Dec 28, 2013 | LuxPro PSP711TS Touch Screen Programmable...
Snowflake symbol on thermostat
Copy following link for Lux product manuals
http://www.luxproducts.com/instructionmanuals.php
It might mean that AA batteries needs to be changed.
Or it might mean 2nd stage heating cycle.
Air filter needs to be changed.
Tech assistance 856-234-8803
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 26, 2012 | LuxPro PSP711TS Touch Screen Programmable...
PILOT LIGHT KEEPS GOING OUT.
If the pilot flame is weak, when the main burner is ignited, there can be enough 'whoosh' of air and gas to blow out the pilot. There may be a little of grit in the pilot valve jet hole restricting the flow, hence the weak flame. Try using a piece of fine wire to clear the obstruction. If that does not help the pilot jet will have to be unscrewed and cleaned with compressed air. Ensure the gas is turned off before attempting any maintenance.
Sep 13, 2010 | Reliance Water Heater #6-40-GBRS 40GAL...
Bosch PowerStar125 won't heat and I can't get one element to work
It sounds like you have a copper canister unit. Ohm out the elements in that one canister. the directions are on the websight for bosch, or I can walk you through it. But you will need a digital multimeter to do this. If you have a blown element in that one canister, then the tco will not reset.
Jan 01, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Rinnai Energysaver 1004FTR (nat gas) RED FLASHES
The filter light can also indicate a build up of debris and lind behind the heater causing the blower to work harder to push out warm air. It could also indicate that the blower may need a cleaning or going bad. I will suggest that you pull the front cover off of the unit to inspect the blower which is located at the top of the heater. Feel the motor as it is running to see if it is hot. If so, you will probably need to replace it. I may have a used on so let me know. If everything in front looks good, pull the top trim panel off of the heater just behind the filters and inspect for dust. Clean with a shop vac. Hope this helps.
Dec 18, 2008 | Water Heaters
LuxPro PSP711TS Touch Screen Programmable Thermostat Logo
10,792 people viewed this question
Top Lux Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Lux Water Heater Expert? Answer questions, earn points and help others
