My red light is flashing 6 times and from what I've read it is the thermal fuse. Where can I find it or a diagram of where it is. Thanks, Nick
SOURCE: Sony Grand WEGA KDF-60XS955
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
SOURCE: sony kdf 50e2000 fans not working now: read below...
hi, Why did you change the thermal fuse - specify the original problem, where the fans working before and need the correct model number before I can help you.
Model kdfe2000 is not listed anywhere.
SOURCE: Sony KDF-55xs955 TV will not turn on. Red LED flashes 6 times.
This sounds so simple, but this is what i gathered from Sony's website. Sounds to me like it may be a service issue.
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
SOURCE: 6 red blinks wont turn on sony rear lcd projection
thermal fuse. it sits below the lamp and has popped. replace with new fuse or just short (eliminating fire protection) let me know if you need instructions.
SOURCE: Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
I fixed my problem by removing the lamp and vacuuming the hell out of the hole where the lamp lives and also getting all of the dust out of the rear ventilation grids with my vacuum. I put the old lamp back in and what do you know the TV has worked perfectly ever since. My lamp was over a year old and did not show any signs of hazing on the lens that you might see on a lamp that has a ton of hours on it. I just thought I would try to put it back in before I spent a couple of hundred bucks on a new lamp.
TA DA problem fixed.
