Question about Samsung ML 1210 Laser Printer
Who is Open Fuser error
Ope
Posted by motaz ahmed mohammd... on
Darren Stagg
    New Friend:
  • 61 Answers
The fuser is the last stage of the printing process - it's what "fuses" or basically bakes the toner into the paper. It's a hollow metal tube with a heater element inside it - that element (lamp) has to reach normal temperature or it will give you that error. Could be the lamp itself burned out or could also be an electrical problem in that circuit. Requires a technician to replace the lamp.
Posted on Jul 16, 2012
Casio Ce 4700 Ope error appears. How can I fix as I can't use till
Hi. Did you get it going?
Ope error just means you pressed an incorrect sequence of buttons. If you still have trouble, tell me exactly what buttons you pressed to make the error appear
Apr 30, 2016 | Retail Supplies
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
Error code E000840-0001incanon ir 6055
My machine canon ir6055 display error E000840-0001 and E00060-0001 i am all so cheek the machine fuser unit last time automatic open the lock fuser i am set the fuser agin problem
and E000013-0001
Jan 17, 2013 | Canon imageRUNNER 5570 Copier
Error fuser unit hl-5350Dn
The fuser unit is located at the rear side of the printer.
Fuser unit error indicates one/more of the following.
1. The fuser roller/film life is over. Replace with new one
2. The fuser film is torn. Replace with new one.
3. Fuser heater is burnt. Replace the heater.
4. Fuser thermal sensor is open. Replace it.
sonsunny
Jun 28, 2011 | Brother HL 5250DN Laser Printer
RRV bucket error lotus notes 8.0
RRV bucket is corrupt occurs when opeing mail file. Unbable to open archieve folder. We are using lotus notes 6.5 version. Pls help.
Nov 11, 2009 | Computers & Internet
Open heat error
Open heat error is a fuser error. If you have plenty of clearance around the printer and you are still getting this error, it is the fuser.
Mar 24, 2009 | Dell 1600n All-In-One Laser Printer
Ricoh FX16 open heat error
the Open Heat error indicates that the sensing circuitry for the fuser has detected that the fuser is not heating up. This can occur because either the sensing circuitry isn't detecting correctly or the fuser actually isn't heating up. Probably the latter in most cases.
How to fixya? Probably install a new fuser and you'll be fixed. Want to be sure before you spend $$ ?? Pull the fuser out. You will see a wiring hookup with two heavy wires that supply 110V to the heating lapm. Connect an ohm meter across the two wires that are on the FUSER. A good fuser will read around (0) ohms - complete circuit. A fuser with a bad lamp or a bad thermostat will read infinite resistance (open circuit).
The thermostat is probably available as a separate item. It's probably about $15 from several online sources. I believe you will need a JC47-00013A. I could be wrong. You'll need to do some research if you find that to be the problem.
Jan 26, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Open heat error
Most "Open Heat Error" messages are caused by a bad fuser. Order a new fuser from Dell.
May 22, 2008 | Dell 1600n All-In-One Laser Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell [email protected]
Apr 21, 2008 | HP LaserJet 4350 Printer
Open Heat Error
the thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Sep 27, 2006 | Dell 1600n All-In-One Laser Printer
Samsung ML 1210 Laser Printer Logo
87 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
