Computers & Internet Logo
Posted on Jul 16, 2012
My emachine T2958 would not boot. the fans run but no bois nothing. i realise on the mother board alight is on by the letter F.Is it the motherboard ? help please
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jul 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
6508
Points
74
A good way to tell is disconnect your hard drive's, & CD/DVD ROM's power & data cable. Try to boot.
If you get the same results then you can try & remove any PCI cards from the board, remove your ram stick. Try to boot. If you get an error beep because you are missing ram than this is good.
Replace 1 ram stick back into your motherboard & try again. If it boots then you know the other stick is bad.
If removing all the non-essentials from your motherboard doesn't work then all you have left are the motherboard & power supply. A simply power supply tester or spare power supply will tell you if it is your board or not.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Aug 20, 2006
SOURCE: T2958 motherboard connections
Concerning the pin locations and polarity they are printed on the motherboard close to the pins. Also, your power supply is failing. I have a customer with the same problem, the power supply needed to be replaced and also the motherboard because it would not even boot to post.
Anonymous
  • 8 Answers
  • Posted on Mar 12, 2008
SOURCE: Where can I get a replacement motherboard for emachine T2984?
Here is a site where you can buy one for a relatively good price....hope it works out.
Anonymous
  • 236 Answers
  • Posted on Mar 26, 2008
SOURCE: emachines wont boot
Could be a cmos battery, try changing it. Sometimes that works.
vr24cod
  • 107 Answers
  • Posted on Apr 03, 2008
SOURCE: emachine t3958
First check to see if a drive died. Unplug all the drive Floppy, hard and dvd or burns. I have come across many time that a drive will die and keep motherboard from booting. Being that you say you get a green light on the motherboard shows that the power suppy is providing some power. But for some reason the internal self test is faulting the power suppy. I have not come cross any bad power supplies killing a motherboard. But I have come across power supplies killing drives. The power switch is a normal open switch so the only time you be able test continuity on it is if you hold the switch in, or the closed position.
Anonymous
  • 135 Answers
  • Posted on Mar 14, 2009
SOURCE: eMachine T2482 Computer won't power on or boot up.
Check the power connection physically make sure that it is connected properly, try other power outlets, if still nothing happen? the problem is on the power supply of the computer, you might replace it. it think there's no switch on the mother board.
Emachine T2958, tested power supply (good). Green
Is your PC making any beep sounds, anything at all on monitor? if nothing try removing cpu then re-install cpu?
1helpful
REPLACED MOBO INTEL D845EPI/845GVSR EMACHINE 2.5 P4 REPLACED PROCESSOR... NO DISPLAY OR KEYBOARD RECOGNIZED, NO BEEPS NOTHING BUT FANS ARE RUNNING AND LIGHTS ARE ON?
1.*********** Board not supporting Your Processor.
2. Try With Lower Speed Processor
3. Mahe sure that Mother Board is Working or Faulty.
4.Check the ram twice
If it HELPS RATE ME!
2helpful
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
2answers
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Need to change mother board
WRONG ON THAT I HAVE ALL THE BOIS INFO YOU NEED.
WWW.lemig.umontreal.ca/bois/bois_sg.htm
www.ping.be/bois/numbers.shtml
www.allelec.com
email: [email protected]
www.unicore.com
go on line type in
update bois or upgrade bois
enter
typing in the bois name and date will tell you about any update or chacges and how to get the updates for free'
bois download drives my work also
rod
ps if you want mother information buy the new cpu magizine [ computer powers issue march 2009}
give you mother boards cpu cooling options cpu venders and option and more info check it out
rod
Can not save current bois version: P4S8X-X BOOT BLOCK
I sent my system with intel desktop mother board and IntelPentium 4 processor to a service center for repairng. it cannot take key board and dont step into bios. but the service centre damaged my board and processor now. so how can iknow the prcessor original?
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
1helpful
2answers
Emachine T2958 will not turn on - has no power
Dear asksforhelp,
As u have told that u have change the power cord then the second thing u can try that check the SMPS is it working or not to check this u have to know that where is the SMPS where u pluged in the power cord in the cpu that thing is SMPS check wether the SMPS fan moving or not if no then u have to replace the SMPS if it is working then u have check wether the mother Board get the power supply or not check the 12 pin power connector insert it in mother Board if still it not working then it is definatly problem with u r Mother Board. So it is better for u that to go for New One.
6answers
Sounds like a power supply problem, I would check out a power supply tester, usually about 19 bucks, but now adays you can buy a decent power supply for 20 bucks, but before you can and spend money, be sure that everything is connected properly. im searching google now for the pin locations, but if you know what type of motherboard, it will make my search so much easier. ***reply to your other post*** all you need to do to get the hard drive to work in another machine is format the Master Boot Record
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
