Question about Motorola Mobility RAZR V3xx Cellular Phone
How do I resit my razr 3 APN
Changing from ATT to Straight Talk
Posted by Jim Root on
  • Jim Root
    Jim Root Jul 17, 2012
    I have Straight Talk SIM Card installed. I also have the $45.00 unlimited Data Plan. I still can only send and receive phone calls. Straight Talk says APN has to be changed, I need to know how to get to the place in the settings to make the change. HELP! Please. Thanks............
How do I make sure my galaxy mega is set to the correct settings
I just switched my att galaxy mega 6.3 to straight talk using the recommended apn straight talk gave me every thing is great except for mms picture messaging which I don't really use it sending almost all pictures through Facebook I was wondering about doing a factory data reset to get all the unwanted att apps off quickly if I do will that mess up my new apn settings?
Pass4Sure 210 260
May 11, 2016 • Cell Phones
Straighttalk settings for blu phone
try this one
had the problem going through forums trying to find the settings that work for my phone but to no success but I finally figured it out and I'm posting it on here just in case some one else has my same problem.
I had to create two separate APN's one for internet and one for MMS. Settings are as follows:
Internet:
Name: Straight Talk Internet
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: Not Set
MMS Proxy: Not Set
MMS Port: Not Set
MCC: 310
MNC: 410
Authentication Type: PAP or CHAP
APN Type: Internet
APN Protocol: IPv4
Bearer: Unspecified
MMS
Name: Straight Talk MMS
APN: att.mvno
Proxy: Not Set
Port: Not Set
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
MCC: 310
MNC: 410
APN Type: Internet+MMS
APN Protocol: IPv4
Bearer: Unspecified
Do not forget to create two separate APN's!!!!!
goodluck
Need apn settings for at&t straight talk Samsung galaxy discover.model sgh730g at&t4.0.1.1 when first got phone it showed. 4g.phone it blacked out called straight talk they had me changed the apn settings...
Straight Talk AT&T APN Name ATT 4G LTE APN tfdata Proxy proxy.mobile.att.net Port Username Password Server MMSC http://mmsc.mobile.att.net MMS Proxy proxy.mobile.att.net MMS Port MCC MNC Authentication Type PAP APN Type default,mms,supl,hipri APN Protocol IPv4
Sep 11, 2017 • Cell Phones
New APN info is not working complete
There are different types of APN set up for Straight Talk. My recommendation is that you add more APN from Straight Talk and select each one to troubleshoot. See, believe it or not, there different APN for different smartphone. You just need to select the right one.
Try this setting here if it's different from the one you have.
http://apn.gishan.net/settings/500_11_straight_talk_apn_settings_for_sony_xperia_z.php
2answers
Pantech p9020 and straight talk
Go to settings > Connectivity > Network Connections > and click "Create" on the bottom of the display.
Then you can enter the settings you were told.
A video for you if you're still confused
https://www.youtube.com/watch?v=AqXf4OgUnuU
Here are the settings I found over the internet. Take a look at it. But I am not sure the service provider is the same though. You better enter the things you've been told by your service provider
Settings : https://bestmvno.com/apn-settings/straight-talk-wireless-apn-settings/
1helpful
Unlock codes for huawei u8652 fusion
Huawei U8652 Fusion
How to make the data work when switching from ATT GoPhone to Straight Talk
(you do NOT need any unlock code!!)
1. go in to settings, wireless and network, make sure wifi is off, then go to mobile networks, make sure data is on, and open access point names.
2. click menu, reset to default, THEN click menu, and new apn like this (if not on this list, leave alone!):
APN: wap.tracfone
Port: 8080
MMSC: http://mms.tracfone.com
3. click menu save, then go back, select the straight talk apn you created.
4. turn phone off, turn phone on, and data should now work!!!!!!!!!!!!!!!!!!!!
Feb 25, 2012 • Cell Phones
Motorola Mobility RAZR V3xx Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Fred
Fred
Vernon Taylor
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
