Question about Zynga Texas HoldEm Poker
A lot of players like me is lagging badly plz put this right
Lagging so bad losing chips cos of it plz put it right
Posted by colbenny on
com_soso85
    New Friend:
Hlal
Posted on Jul 17, 2012
1 Related Answer
White Zombie
  • 4961 Answers
SOURCE: the game on poker is lagging all the time ppl all over gettin problems please can u sovle it now its putting ppl off playing
Update your Adobe flash player software to the latest version:
http://get.adobe.com/flashplayer/
If that doesn't fix it you might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Posted on Jul 15, 2012
Xbox 360 slim offline lag
Hi dinobots,
Do you use Wi-Fi or an ethernet cable? If you are experiencing severe lag, it could be a problem with your actual internet connection and not necessarily your XBox 360.
I would purchase an ethernet cable (they run about $10 over here in the states) and try that out before anything else
Mar 19, 2012 | Microsoft Xbox 360 Super Elite (250 GB)...
I am having power problems with my Toshiba A205. When I plug in the power cable, my laptop freezes. When I take out the power cable, I need to shut down and restart before I can get it to work. But once my...
okie thank me a lot first cos i have the solution or atleast the reason... hate me cos i am the bearer of possibly bad news... the problem is at chip level... a processor needs to be supplied with uniform voltage and power for uninterrupted operation whil handling huge calculations it is not capable of withstanding sudden changes in voltages... for this purpose what we have on a mobo is a chip called the core voltage controller this chip makes sure that the voltage sent is uniform... this chip on ur system is blown
2 solutions exists take a deep breathe relax one is to replace the mobo-cost approx400$ take a deeper breathe ask for toshiba assistance instore and get this chip replaced cost 100$(i took the second option costed me 4500 rupees in India)
Aug 03, 2010 | Toshiba Satellite A205-S4617 Notebook
I have a game lag(games like War craft and Counter strike)...all drivers are up to date..system spec are also high..dont know what to do..plz help(( my laptop is amilo li 1718..the game lag is not related...
that unit may have decent processor specs but that means nothing because the video card for those are a ATI Radeon 200M. World of Warcraft does nto support that video card correctly and is too slow to make the graphics not lag.
counter strike source on full low everything will run fine on this video card but the game will look bad.
Jun 03, 2010 | Computers & Internet
Social Network: I have bad lag when playing texas holdem on facebo...
Update your adobe flash player to latest version. here is the link.. access and choose from any mirror site and start downloading. then install flash player to load your games faster than before.
http://www.softpedia.com/progDownload/Macromedia-Flash-Player-Download-24146.html
May 18, 2010 | Facebook Social Network
On my DLP (HLS5086W) several white dots are on the screen, all sources. Does this mean the DLP processor chip is bad?
YOU MAY HAVE A COUPLE OF DUD PIXELS.YOU MAY HAVE TO PUT UP WITH THIS.WOULD COST A LOT TO REPAIR.NO THE CHIP IS NOT BAD.
May 01, 2010 | Televison & Video
Intermittent Lag
lag is in most online game's , to combat this you need a few thing's 1) good processor chip, 2) lots of memory 3) good service provider (up the meg rate if poss for online gaming 8meg minimum is good , , In game turn down any unwanted graphic's to low setting to run smoother.
Apr 15, 2009 | Activision Soldier of Fortune Gold Edition
The dvd player posts a message "can not play." I have tried several dvd's and none are playing.
Open the case. Disconnect the ribbons from the main control PCB. Remove the screws holding down the PCB and the rear connectors. Take the board out. Find a chip with the number MR27T1602L or similar - it is called a P2ROM. Run a screwdriver slowly all around this chip to possibly drain erroneous (yea right) data. There is a small chip diagonal to the P2ROM right next to it. I could not read what it was but i suspect it is for temporary data storage - possibly a serial ROM of some sorts. Run the *SMALL* screwdriver around the 8 legs on that chip slowly ensuring that it connects each 2 legs to each other along the way. Now this will either 1) Do Nothing 2) Mess up the chips or 3) Clear out any bad (read factory installed failure timers) data from the chips. Doing this task over a period of about 3 hours seemed to have solved the problem. Now it could have been as simple as disconnecting the ribbons to the board and leaving it sit for a few hours to drain (memory caps to lose charge). I don't know. But I know after doing this my player started working again. Good Luck to all who try.
Mar 31, 2009 | Sony DVP-NS57P
Cannot play disc
a burned disk u will need newer samsung unitto rea dthem all older units dont read well burned dvds ok upgarde to latest players so it can read it right
Oct 14, 2008 | Sony DVP-NS57P
Very Bad Lag
  1. Well i have a other problem with my ipod. When i hooked my ipod up to my computer with my usb cable. When i try to put song music video and movies on my ipod it wont let me because i only have two folders on my ipod. i have candler and News on my ipod. I wont to do i have to download files to my ipod or what do i have to do. i just need a lil bit of help from you.
thank you.
Oct 14, 2008 | Apple iPod MA446LL/A MP3 Player
Zynga Texas HoldEm Poker Logo
140 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Vincent G
Vincent G
Andrew Taylor
Andrew Taylor
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
