If you don't know about calculator electroncs, you don't have own means to repair it so take it to a repair technician, ask a diagnosis and evaluate if it's worth to repair your calculatoe or dispose of it.
Try pulling the switch open, and clean the contacts, or make sure everything still connects as it should. Check your connections at the starter and solenoid.
IMPORTANT NOTE: You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer! You can find the radio code at: http://www.radio-code.co.uk/
The sequence of VW radio gamma programming is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Look about 5" from the compressor on the hose assy,
suction or return side
If you need to add refrigerant,& you won't know that
you do,you would have a leak & be breaking federal
laws by trying to add & then poluting the atmosphere
You car & and Lincoln LS are twins for the most part
You need a knowledgable a/c person & a scan tool,
as well as the usually a/c equipment you won't have
You can not add to any vehicle system,as you will let
air into it,it won't take ref under prressure & you may
overcharge it & ruin the compressor or worse
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer! You can find the radio code at: http://www.radio-code.co.uk/
The sequence of Audi radio programming is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
