Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
SOURCE: panasonic panafax uf-790 error 021
you might be able to do a lbp fuser reset might clear the problem or you do have a bad fuser
Posted on Sep 10, 2008
SOURCE: error 021
you can try a lbp fuser reset. leave me an email i will tell you how to do it. or unfortunately you do have a bad fuser and when you replace it you need to do a fuser reset anyways.
good luck
Posted on Sep 22, 2008
SOURCE: fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Posted on Apr 09, 2009
SOURCE: panafax uf-895 faxes, won't print. Put a new toner
Error 021 relates to the Fuser unit (the bit that gets hot inside).
It is not related to the toner, which is a bit strange, but try switch off/on first.
Failing that you may need to clear the error in service mode. To access this:
Press "Function", "7", "Monitor" four times, then "*".
The machine should be saying "Service Mode"
Then press "7"
The machine should say "LBP Parameter Set"
(not 100% about the next bit but it should be reasonably straightforward to follow the display on the machine)
You are looking for "LBP Fuser Reset"..I think it is this:
Press "2" for "LBP Fuser Reset"
Press "Start"
The machine may reboot at this point.
If this is done correctly and the error still remains, the Fuser Unit will need replacing.
Sorry to be a bit vague on the instructions..not worked on these for a few years :)
Posted on Jun 19, 2009
SOURCE: We are getting Error CODE 021 on our fax machine
Check the following information............
http://www.fixya.com/support/t3509371-our_fax_following_error_message_printer
Posted on Sep 24, 2010
Sep 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Sep 22, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Sep 13, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Jul 17, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Jun 08, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Aug 03, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Aug 03, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Apr 01, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Jun 19, 2007 | Panasonic PanaFax UF-490 All-In-One Laser...
79 people viewed this question
