Question about Precor EFX 546i Elliptical Version 4
The ZE5 elliptical has developed a loud annoying repetitive squeak. Any suggestions to get rid of that?
Posted by Dale Foshee on
Sportsmith LLC
  • Precor Master
  • 918 Answers
You could try lubricating the moving parts. Sometimes the bearings and the connecting parts can become dry. If lubing does not work, it may simply be time to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
Posted on May 20, 2014
Squeaky elliptical
You can download the picture and zoom it ! Has a few options of the possible squeaking noises. Hope this helps. Could be level, screws, guide rails 6_7_2013_7_23_55_pm.png
Jun 02, 2013 | Exercise & Fitness
My Nordictrack E9.0 Elliptical machine has a loud squeek
I have found a possible source for your squeak. I have the same elliptical and had an annoying squeak in the front end of the machine. The squeak could be coming from the roller arm flex bracket and/or the pedal arm flex bracket. These brackets are secured to the front of the roller arms and the pedal arms with a single bolt. Tightening these bolts may help get rid of the squeak. If you don't have your manual, you can download the manual at the nordictrack website. The manual will have an exploded drawing of the elliptical. The roller arm bracket and the pedal arm bracket are numbered 135 and 136 and you will see which bolt I am talking about. I have had numerous issues with my elliptical but after changing some parts under warranty, it is working like new. Good luck.
Mar 19, 2013 | Exercise & Fitness
Life Fitness 9100 Elliptical Squeaks
You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
Nov 24, 2012 | Life Fitness 9100 Elliptical Cross Trainer
My elliptical trainer is starting to squeak. What should I do?
Don't worry; this is a common problem in elliptical trainers. Over time, parts of the machine may start to squeak. I am going to attach a how-to guide that will explain what to do when this happens.
http://www.livestrong.com/article/269134-how-to-stop-an-elliptical-from-squeaking/
Aug 02, 2012 | Exercise & Fitness
My proform 10.0 ze elliptical has developed a repetitive squeak in the rear drive...any ideas for a quick fix?
It sounds like the sleeve bushings maybe dry usually penetrating oil will take care of this problem. If not you may need to replace bushing then go to iconfitness.com to customer service then to replacement parts you'll get part# and Pricing
Feb 22, 2010 | Exercise & Fitness
Proform XP110 R recumbent bike makes clanking noise.
I have the same problem with my XP 110. After taking the ENTIRE thing apart and independently testing every single moving mechanism, I found out that it wasn't the motor, pedals, armbars, or any internal mechanism. Instead, it was the front stabilizer foot that made the annoying noise. There is a plastic mechanism around the front stabilizer legs that holds the front wheels in place (for moving the elliptical). Whenever a rotation forward occurs, the plastic squeaks and the noise resonates to make it sound like the pedals or motor is squeaking. I am still trying to find a solution to fixing the feet, but may end up ordering a new set from the manufacturer. Good luck with your elliptical!
Mar 22, 2009 | Exercise & Fitness
Squeak
PHOTPSMART PRINTER 4180 MAKES SQUEAK SOUND WHEN SCANNIN
Aug 14, 2008 | HP Photosmart D5160 InkJet Printer
Squeaking
that's a mechanism issue inside..it's going to fail quite soon, so you may not have this problem for too much longer.
Aug 07, 2008 | Brother MFC-8860DN Printer
Precor EFX 546i Elliptical Version 4 Logo
439 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
Ngoro
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
