The projector runs fine with a good bright display but keeps shutting down after a minute or less. The operating lights on the top are working as per manual and the light for bulb replace is not lit. I don't think the bulb needs to be replaced and the fan screens are clean I just don't know please help.
SOURCE: cannot reset projector after new lamp installed
hi
Have you reset the lamp timer after replacing the lamp, if not then do so and see the user manual for that.
Viren
SOURCE: lv-s1 canon projector
Hi there
Open up the unit and replace the fuse on the Powersupply ( where the AC inlet sits )
If this doesn't do the trick you will have to replace the Powersupply itself.
But most of the time it is only the fuse that has gone.
SOURCE: canon lv-s1
Update the problem in details. And you can get the same in canon authorized service center.
Regards,
prakasam
SOURCE: Big Green Bar
Hi Tom017
Does this green bar show even when there is no signal inserted into the Projector ?
If it doesn't then you can try using a different cable - that should solve this for you.
If it doesn't then you might be in for a quite expensive Mainbaord repair or replacement.
Good luck and thanks for using Fixya !
SOURCE: Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
