Question about Harley Davidson KNG America 026711 Harley-Davidson Fat Boy Replica Phone
I have a Harley-Davidson Heritage lamp and a 63 Sting Ray Corvette lamp, they both have sound and they both stop working.
Posted by Bob Bengala on
5 Related Answers
Anonymous
  • 150 Answers
SOURCE: 2002 harley davidson heritage softtail
ok first let me clue you in on a little tid bit you might be unaware of. HD has been making motorcycles for, well, over a hundred years bro! a make and model might help eh?
Posted on Apr 18, 2008
Anonymous
  • 25 Answers
SOURCE: tire pressure
36-38 in f 38-40 in r, unless metzler then 40 on both
Posted on Nov 26, 2008
Tom Diffin
  • 95 Answers
SOURCE: oil drain plug
its not a plug its a hose look under the tank on the pipe side, look for the hose thats goes to the bottom frame rail (tube) thats the drain hopes this helps
Posted on Jan 01, 2009
Tom Diffin
  • 95 Answers
SOURCE: What is the normal oil pressure on a HD 2005 Heritage Springer?
hello you didnt say what oil you run (weight 10-50 20-50 conv, or synthetic) as a average pressure at idle as low as 10psi and running down the road as high as 50psi
Anonymous
  • 150 Answers
SOURCE: removing front wheel from harley davidson heritage
first take off the brake caliper takes a 10 mm socket..Next jack front of bike up just enough to take pressure off front tire...take off the axle nut lbit more to take pressure off axleock washer and flat washer...Next remove two axle support nuts from the right side of bike 1/2 in socket. now jack bike up a hair more to releave pressure off axle push, hammer with a rubber hammer or what ever it takes to drive it through. jack bike up so it clears fender. Sometimes the tire won't clear the fender bolts if so just release air from tire and it will clear. good luck. Its not hare at all.
Posted on Jun 14, 2009
Need replacement parts for harley davidson floor lamp where can i get them?
Check online with HD or Amazon. You should be able to find a part number to help in your search.
Oct 16, 2018 | Harley Davidson Lamp Heritage Sound N...
How do I remove on off switch on my heritage passing lamps
Hi Anonymous, I'm sorry you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below: Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 02, 2013 | 2011 Harley Davidson FLSTC Heritage...
How to retrive the codes on a 2002 harley davidson heritage softail
Hi Ray, for more information about your question please visit the website below. Good luck and have nice day.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Apr 01, 2012 | 2002 Harley Davidson FLSTC - FLSTCI...
Hi Ray, please be aware that this question has already been asked and answered. Thank you.
Need a new shade
I don't know if you can buy the shade separately, but you can buy the lamp for 50% lower than its MSRP here:http://www.ecrater.com/p/3690265/harley-davidson-lamp
Mar 13, 2012 | Harley Davidson Lamp Heritage Sound N...
King America Harley Davidson Lamp does not work.
If you remove the six screws holding the base of the lamp together (one is under a rubber foot), you will find a circuit board which controls all functions of the lamp. Look for a small 1A fuse that is located on the top side of the board. Remove and replace with a new fuse. I purchased a pack of two in the electrical dept. at Ace Hardware. Everything on mine now works again!
Jul 17, 2011 | Harley Davidson Lamp Heritage Sound N...
I HAVE A KNG AMERICA HERITAGE SOFTTAIL LAMP THAT HAS A NIGHT LIGHT AND MAKES ENGINE SOUNDS THE BULB BLEW OUT AND NOW THE LAMP WONT WORK AT ALL NOTHING
Hi Cruzn2006, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Jun 16, 2010 | 2003 Harley Davidson FLSTC Heritage...
Do not have tail lights on my 1997 harley davidson
using a test light start at the flasher if you find no power there look back to the battery if you have power at the flasher trace the wires back to the turn signal lamps
May 05, 2009 | 2000 Harley Davidson FLSTC Heritage...
How/can you jump start a 2002 Harley Davidson Heritage Classic
easy
put the bike in gear, rock it backwards to off set the pistons; the stop at the same level; this gives it direction. the normal jump start.
fxdxt
Mar 22, 2009 | 2002 Harley Davidson FLSTC - FLSTCI...
Harley Davidson KNG America 026711 Harley-Davidson Fat Boy Replica Phone Logo
79 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
Steve F
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
