I can put in the code sometime and it stays but then it just goes out again again only on the tv side not the box side. I would press the program key, ok, 067 (code for pioneer), then the tv key sometime time it worked. when it went out is hard to set back in, even with new battieries in. Please help.
SOURCE: Remote control programming codes
i have a GE t.v. and just bought the RCA DTA800 converter box. none of the codes that were in the manual worked for my t.v. can anyone help?
SOURCE: Haier / Celera TV & RCA Converter Box remote code
hi guys,
pgm-->tv code-->ok-->you are done
try this link for codes.
http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
hope you got it.
Satya.
SOURCE: Remote codes for RCA Digital TV Converter Box (DTA800B1)
I was just looking for them and then found my manual and felt bad for you guys so I scanned it and uploaded it to photobucket ^^ please feel free to save the remote codes but you may have to zoom in alot to see them ^^
http://i37.photobucket.com/albums/e83/Megumi_Kurama/Scan007December152008.jpg
http://i37.photobucket.com/albums/e83/Megumi_Kurama/Scan006December152008.jpg
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable. The Installation Guide should appear. The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
SOURCE: Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
No, I already tried that also. I got it back it again but dont no how long it will stay in. Thats my problem when I do get the code computed in in it does not stay in.. I really do appreciatte your help though, thank you so much.
