I have reset times before no prolems-when I PROGS. #1 prog. shows no time-ck.d all days all are set-the will not set prog._*1
Hello Terry. Which GE digital timer do you have?
Copy following link to identify timer, and download manual.
http://waterheatertimer.org/GE-timers-and-manuals.html
Reset timer using reset button.
If timer has no voltage, then check outlet.
Check circuit breaker.
Check that light bulb is good.
If timer is plug-in type, then test outlet with circuit analyzer. Try timer in different outlet with different light.
Re-post question with timer model number, and things you have tried so far.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
SOURCE: How to set start time on timer raindrip r672c
The start time on these style of timers is whenever you set it. So if you want it to run at night it needs to be set at night, e.g. turn to off/reset, then at 10pm go set to the freq. and duration desired, then it will run at 10pm. Also note this timer waits a full cycle to run the first time after it is set, e.g. if today you set it to run weekly, the first time will be next week.
SOURCE: GE Digital Time Switch (15132) for basic landscape lighting
Leave the breaker off, remove the wires from the timer and just connect them. then turn the power on. Unless you have a short somewhere, the lights should come on. What you have just done is made the breaker your switch. If the breaker kicks you know to keep looking for a short as it is not the timer. Regards, Joe
SOURCE: I just installed a GE Smart Digital Timer. After
Timer wiring instructions shown on following page:
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
You connected the white wire and red wire together, and that is why lights are clicking on-off.
I test timers and have done this intentionally during testing.
Follow instructions shown on link above, and GE timer will work correctly.
Same wiring applies to Tork, Swilight, Utilitec, Woods, Leviton, Intermatic non-battery operated timers.
Instructions are different for Aube, Brinks, UPM and Intermatic battery operated
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
