Kitchen Appliances - Others Logo
Question about Gold Medal Kitchen Appliances - Others
Where can i buy a heat lamp bulb for my popcorn machine
Heat lamp bulb
Steve King
Go to http://www.PopcornBulbs.com
Posted on Oct 29, 2020
1 Related Answer
Anonymous
  • 1952 Answers
SOURCE: heat lamp for goldrush popcorn machine
www.thefind.com/.../info-popcorn-machine-maker-poppe click this link
Posted on Jul 23, 2009
I have a popcorn machine model UE40010 that needs motor complete with gears, light switch and Bulb. Unit has never been used.Was delivered damaged.
Send it back under warranty??
popcorn maker - Nisbets
media.nisbets.com > media > 8oz popcorn manual dist
PDF 8oz COMMERCIAL POPCORN MACHINE. MOdEL NO. & SPECIfICATIONS: Model No.: UE40010. Voltage: AC 230V~50Hz. Input Power: 860W. Please read ...
c72a87b3-8247-4c28-b549-a034aa485c1e.pdf
images.homedepot-static.com > catalog > pdfimages
PDF For Great Northern Popcorn Company Models: 6000 Roosevelt Full ... 4OZ POPPER ASSEMBLY. Model No.: UE40010. Voltage: AC 120V-60Hz. Input Power: ...
Popcorn Machine Parts & Accessories at WebstaurantStore
www.webstaurantstore.com > ... > Popcorn Equipment
Find replacements for your popcorn popper with our popcorn machine parts & accessories! ... Kettle for PMW17R (Digital Display Models). #382pmwkettle. ‎Gold Medal Popcorn Machine ... · ‎Carnival King · ‎Paragon Parts and ...
What kind of lightbulb goes into my great northern popcorn machine
Does it have a bulb in it now? Try an appliance bulb you put in your over. They are around 40 watts. It may work if it has the correct socket.
Popper does not work when plugged in
the heat coil shorted the fuse blew; throw it away
Need to know where to buy a light bulb 120 volt 820 watt
There is no such light bulb, I assume that is a typo.
Bring your old light bulb to the hardware store with you, they will have one that matches. The lights are just standard lights, not heat lamps.
1helpful
Where do I get a new bulb from for a paragon concept 4 machine
You can get it at any hardware store. They are just spot lights, they are not heat lamps.
Some people want the shatter resistant type, you will have to contact a Popcorn Dealer for that style, but it really is not necessary.
Our popcorn machine is blowing the circuit when the kettle heat is turned on. Is there any way to fix it or any way to just buy a new kettle?
Mine is doing the same thing. Did you get yours fixed yet? If so, what was the problem? Its got to be the wiring. If you take off the bottom square wiring cover access, you will see the two main wires and a grounder all connected. Sometimes the connectors melt with the heat. Maybe that is what is causing the short.
Our poper is burning out light bulbs in a about a 2 day period of time
Get either "Rough Service" Or "Appliance" bulbs. They are made heartier than regular bulbs. You can also use OUTSIDE type flood lamps. Make sure you have a cover over your bulb, incase it shatters.
2helpful
Heat lamp for goldrush popcorn machine
Top Gold Medal Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
