Question about Upper Deck 2004 Power Up Orange 30 Chipper Jones NM
How much does a replacement blade cost for my chipper shredder?
Posted by eric bell on
Jack Levi
    New Friend:
  • 31 Answers
A replacement blade costs around $30-$40.
Posted on Jul 15, 2012
Sharping the blades
I dont think you need to remove the fly wheel to sharpen blades. Remove the housing an the blades are visible an removed that way. Not a hard job at all.
Mar 24, 2014 | Central Machinery 5-1/2 Horsepower Chipper...
Cub cadet chipper shredder starter coil is locked - will not pull
REMOVE THE SPARK PLUG. You now can safely take apart the unit to remove the covers over the chipper and shredder blades and remove the material stuck in the blades.
Aug 23, 2013 | Cub Cadet CS2210 - 2" 208cc Tow-Behind...
Is it dangerous to use chippers?
Using chippers and blades can be reallydangerous. Make sure you use the correct safety equipment and follow all theuser instructions. Take a look at this guide with safety instructions http://nasdonline.org/document/1933/d001876/chipper-shredder-safety.html
Jul 17, 2012 | Fleer 5 2001 Focus Chipper Jones 130
Replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
Mar 12, 2010 | Troy-Bilt Chipper Shredder
I have a troy built 250cc chipper shredder.. it
hi yes you can. when you take the back off you can reach the cuttingwheel and clean everything. after that its ready to use again.
Jan 30, 2010 | Troy-Bilt Chipper Shredder
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I have a craftsman chipper / shredder and it doesn't do a very good job - is there a piece to change or a blade to sharpen?
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Nov 24, 2009 | Troy-Bilt Chipper Shredder
I have a yard machinne 6.5hp chipper/shredder -
Oct 08, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Upper Deck 2004 Power Up Orange 30 Chipper Jones NM Logo
75 people viewed this question
Top Upper Deck Heavy Machinery Experts
Bill Boyd
STEVE SPAM REMOVER
Tom Chichester
Are you an Upper Deck Heavy Machinery Expert? Answer questions, earn points and help others
