Flat
washers are most commonly made of steel; however they can be found in a variety
of other materials such as brass, silicone bronze, chrome and rubber.
The spring washer goes between the nut and the flat washer, so the sequence of assembly would be:
1) slide flat washer on bolt
2) slide spring washer on
3) thread nut on.
Flat washers come in many different s and are dividedinto three series: Narrow, Regular, and Wide. For a complete list of s,check out this website: http://www.engineersedge.com/plain_washers.htm
The different types of flat washers include: ā¢Fender washersā¢Type A washersā¢Type B washersā¢Nylon washers You can find more information on these types of flatwashers on this link: http://www.ehow.com/list_6516551_types-flat-washers.html
Different flat washers are made from different materials.Those materials include zinc, stainless steel, carbon steel, different types ofrubbers, and plastic.
need more info spring and washer don't tell me anything.do you have all the parts.i think your talking about the spring washer that keeps the brush roller from locking up.if thats what your talking about remove the bearing cap off the end of the roller brush.lay it inside the roller concave ppart of the washer down put the cap back on.if both washers came out of thesame side put the spring washer in first then the flat washer
1. install round washer first flat side facing you.
2. round plastic washer next flat side facing the washer.
3. next step blade.
4. next step square plastic washer label facing you.
5. then the square metal washer, make it flash with the shaft flat side.
6. tighten nut by hand at first then use impact tool if you have.
