Dell UltraSharp 1905FP 19" LCD Monitor Logo
lee adams Posted on Jul 15, 2012
No sound Visually the monitor works fine but there is no sound. OS is XP and originaly had an old monitor attached. Have just upgraded to this flat screen.
1 Related Answer
Anonymous
  • 3940 Answers
  • Posted on Apr 10, 2010
SOURCE: My dell S1709W flat panel monitor turned white
http://support.dell.com/support/edocs/monitors/S1709W/en/ug/operate.htm#Using the Front Panel
NOTE: You can also lock or unlock the OSD by pushing and holding themenu-logo2.gifbutton for 15 seconds. (Top of the buttons on right side)
S3842 uk FREEZES ON BOOT every time have to switch off. on 3rd or 4th attempt works fine. any new software that requires reboot - it does this without a problem. started 2 months ago with original Vista...
Upgrades are usually troublesome as they leave bits of the old OS in odd places. It is best to do a clean install.
Choose your OS, either Vista or Win7. XP will not work!
Always download the latest drivers for the OS you are using from hp.com or it will keep hanging and be unreliable.
Hope this helps.
I have an old HP Pavilion a1140n, it was working fine until one day the monitor went blank. The monitor is still good because I connected it to my lap top and it works fine. The problem seems to be with...
obsolete PC, HP has zero support on it
no OS, stated, XP? what XP - service pack 3?
no service tag presented.
sounds like mobo is e-machine, onboard video chip bad,.
yes, most mobo support an old VGA card not sold now.
only used, and must match your machines express card,
voltages, etc. called express level #
the must go to bios and change from internal video to external.
that part is tricky on dead screen. no?
find that card (old) and working used, is problematic, could take weeks to find one... why?
and old old Pentium 4 wow.
why no scrap the best and upgrade to a newer system.
one with SUPPORT?
10 years or newer,
can be had used for like $50 (the brick, no screen)
why mess with OLD IRON like this... time to move on.
no?
why spend a fortune on a PC worth $5 on the street
why?
ever go to GOODWILL>? see vast machines far newer, for NOTHING?
or here, amazing no?
and this, even new boxes are cheap.
H3LL less than one service charge at a shop. Geek something.
https://www.walmart.com/search/?query=desktop%20pc%20on%20sale
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
2helpful
2answers
Do acer monitors just work with vista? i have XP
An Accer monitor will work on most any computer, even a laptop. (plugged into the rear extension port). Weither XP, Vista, or Win98 doesn't matter.
2helpful
2answers
Built in speakers not working
Please try to check it from Control Panel > Sound, speech & audio devices > Sound and Audio Devices > Hardware tab > then select the Device Name then click Properties tab to verify its condition status or you opt to click Troubleshoot tab. regards
No sound upon installing E-MU 0404 pci card and driver
Hey ya'll.
I had the same problem with everything installed,icons on the screen etc...I took my stuff to my computer wizard and he came with the following solution which is:
Make sure that you have a Windows XP "SP2 or GREATER" this is the kicker.Go to the requirements sheet if you need more info.
Anyway I did that upgrade from SP1 to SP2 and it works like a charm with pristine sound.
Good luck fellows.
monsieur M.
1helpful
Monitor resolution (slider) stuck on 4 bit color setting . . .
I would go to http://support.gateway.com/support/default.aspx input your model and os then dload and install drivers for the motherboard.This should fix the problem.
Thanks for posting and please rate
Sean
Blank screen using Vista x64 with Nvidia Forceware Drivers 8600GT
Most like the sound card you have is not compatible with Windows Vista. You need to check the manufacturers website to see if there is any patch for Windows Vista
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
