This is a sound system with turntable, CD, tape cassette and radio
SOURCE: no sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: Turn Table
Activate the turn table by moving the arm slightly to the right until you hear a click.
SOURCE: murano 2003 the radio system is on but no sound coming out
your audio sys should have an ext. amp. check for im the manual to find where the fuse is.
SOURCE: We have a Marantz PM493 amplifier with turntable,
Hiya Sally_fisher,
Is the feedback sound a low hum and also does this 'feedback sound" occur whether it is selected to CD, turntable, or on all of them regardless of select?
SOURCE: How to turn on turntable on Philco Turntable CD Player
Just pull the arm back a little bit, the turntable should then start.
