RCA P52940 52" Rear Projection Television Logo
Question about RCA P52940 52" Rear Projection Television
RCA p52940 convergence pcb
Convergence pcb
5 Related Answers
Anonymous
  • 1284 Answers
SOURCE: Convergence issue at screen edge
Sounds like a technician that failed to do the convergence alignment that should be checked after any repair. No nudging needed, maybe just nudge the technician who fixed it.
Posted on Feb 16, 2007
Anonymous
  • 192 Answers
SOURCE: double vision and no convergence
I have found that fusible link FL231 is the main cause of this problem. It's located by the high voltage transformer and looks like a square coil.
Check it with an ohm meter and if it checks bad, then, replace it and you should not have to realign the convergence.
Any questions or comments, respond to this post and I will reply.
Posted on Jan 01, 2008
Anonymous
  • 298 Answers
SOURCE: Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Posted on Apr 10, 2009
Anonymous
  • 5138 Answers
SOURCE: rca r52wh74yx51 chasis itc222a convergence
These sets do not have convergence ICs it has convergence board most common problem with them is if you go to menu then setup and do not see convergence on menu then you have a open fuse FL231 they are located on right side of FBT flyback transfomer thier is 3 in a roll small brown rectrangler looking caps but are FUSEs it will be the one in the middle.
Posted on Aug 14, 2009
Testimonial: "Thanks I found it immediately and will change it out today"
Anonymous
  • 5138 Answers
SOURCE: My RCA HD52W59 HDTV has a convergence problem. It
On your Deflection Board it is the bottom left hand side board has FBT flyback transfomer on it Blowed Fuse FL231 it will be on right hand side of FBT there is 3 of them in a roll small brown rectrangler looking caps but they are fuses ir will be the one in the Middle Call PartStore.com 1-866-925-7278
Posted on Dec 31, 2009
Has a 3d affect
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any kind colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes all of these problems.The tv convegence board have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Iam getting duplicate picture
replace the convergence OC its a STK730-130 you need only one you can get one at www.tvrepairworld.com
The picture curves in toward center of tv and looks like the colors are out of line.
These units had problems with there convergence power supplies. If the supply quits it will loose convergence correction. It could also be the convergence correction PCB itself. Have a repair shop check it out for you. Thanks
Rca convergence- HELP!!!!
replace the converg pcb inside the tv and realign the picture
Projection RCA P52940
sounds like it is most likely the convergence power supply board, if it were just one color It would most likely be the convergence board itself
Convergence
No menu option is a clue to your problem. No menu option for convergence is due to the Micro not seeing a active convergence module in the unit. This is a post check, when the unit is turned on, and on some units, only done at AC power up.
With that in mind, you need to check your (PW=power) pcb for the conv module. This is easy to find, but on most RCA is located on the plastic panel that is in front of the CRTs. On this model, you should see PW conv PCB on left and Conv PCB on right. Top left corner is a plug with two wires, BP611, (i think) which should have like 300v DC. If you dont have the B+ go to the Primary power supply. More then likely you will have it.
If your 300v is there, order the PW conv module. NOTE: most of these modules are rebuild only and cost about 70.00 to rebuild at PTS. Other wise, you can trouble shoot at board level.
ONLY WORK ON THIS IS YOU HAVE CAN SAFELY USE A METER, AND HAVE SOME ELECTRONICAL SKILLS. NOT FOR BEGGINERS!
Scott
JTV repair.
2answers
Convergance circuit board
Convergence PCB probably not available....can you get me any #'s off the PCB or part # of STK IC or location # of convergence IC ??? ..................Should be worth fixing if I can get alittle more info....................T.
Note to mountain mom: You have a completely different
symptom ..............+ need service #.............
Try DVD ? all inputs ? cable box ? source to RF coax= on ch.3 ?..............................T.
2helpful
RCA P46770CK
Check Cr4503 in the vertical circuit for short or leaking. The convergence circuit is most likely fine. Also check for any leaky electrolytic caps in the 500 block. (example) CR4503 will be printed on the PCB as CR503. The vertical circuit is located in the center of the chassis behind the big aluminum heat sink.
Rca rear projection convergence problem
Convergence outputs reliable.Suspect power supply to control convergence bad.Small PCB mounted above two main PCB.Check STK730-010 & associated circuitry. If This info not helpful, please provide complete service # and chassis number.
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
