Question about Motorola Radio Communications
Motoroala mj270 walkie talk
Motorola two way radio walkie talk about mj270 owner manual
Posted by lelonilyn123 on
eradiostore
  • Motorola Master
  • 1,658 Answers
5 Related Answers
Anonymous
  • 123 Answers
SOURCE: Motorola Talkabout T5100
I think you have to remove the courtesy beep option from radio, this is also call Roger beep.
Posted on Dec 12, 2006
Anonymous
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
Anonymous
  • 67 Answers
SOURCE: I need a manual for a MJ270 walkie talkie,
This should direct you to the right place for a manual
http://www.motorola.com/Consumers/US-EN/Consumer-Product-and-Services/Two-way-Radios-and-Accessories/ci.MJ270R+Talkabout+Two-Way+Radio_US_EN.alt
Posted on Jun 04, 2009
eradiostore
eradiostore
  • 1658 Answers
SOURCE: I need a user manual for the Motorola T5522 two
Here is a link: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf Have a nice weekend.
Posted on Jun 06, 2009
Motorola T8550R
Not all Motorola FRS radio models use the same designations for a give frequency or tone. You may have trouble talking with models different from your own...
Apr 28, 2013 | Motorola Talkabout® T8500R Two Way Radio
Is kenwood walkie talkie and motorola walkie talkie on the same frequence
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
Oct 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Talking
See if the one radio that doesn't hear the other has a PL tone programmed into it. If both radios are not programmed to the same PL tone, then one will not hear the other. Consult your owner's manual on how to do this.
Regards,
Longshorts.
Jun 24, 2009 | Motorola Walkie Talkie 2-Way Radio
T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 02, 2008 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
69 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
