Battery, starter, alternator good and the spark seems to reach the wiring harness at the key ignition but there is just a clicking noise coming from the area around the fuses and wires under the dash. does not even try to turn over, Pretty sure its something electrical with the wires. Looking for any ideas.
SOURCE: engine will not start
That Clicking Sound is Coming from the Starter. First check the Starter Relay. It should be in a Fuse Relay Box under the Hood. If this is good, The Problem will be the Starter and will need to be Replaced. Also Check the Tension on the Belt. If the Belt is even a little loose it will not allow the Alternator to Charge the Battery and will cause a Not Start. Let me know what you find out. Please Rate my Response, I need all the Help I can get! Thanks!
SOURCE: Starter fails to start.
I'm having the same problem. The dealership keeps telling me it's the starter. I've replaced starter and still have the same problem. I have had all the wiring and new key swith put in and still have the same problem. I guess were in the same boat!!!
SOURCE: 2005 Frontier V6 Crew Cab - wont start - battery good - can kick start.
hi i had same problem a few days ago brought to the dealership and turns out there is a clutch stop sensor that if it is not making contact will not allow you to start using the key part cost about $25 with labor it was $113 to be fixed at dealership seems it only last about 30-35k miles before breaking if yours is manual that could be your problem hope this helps
SOURCE: My 1997 Nissan Maxima will not start. It's not
If the spark plugs aren't firing then you just have to follow it backwards. the spark plugs should be connected to a coil or distributor. The problem could be there.
