Question about Acer Aspire Computers & Internet
I want the text to be 150% permanently instead 100%?
Posted by cobbold_mari on
Brian Sullivan
  • Acer Master
  • 27,725 Answers
If you are using word open up word select view from the drop down list select toolbars select standard formatting
open up word across to the left you will see arial times new roman arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
next to that will be a drop down list with all sizes you can change the sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
depending on what page or program font you want to enlarge it will differ
for a general web page
right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
if you need more help with this post a reply
hope it helps
Posted on Jul 15, 2012
How do i make the type larger i can hardly read it
If you have Windows 7 or Vista you can do this:
  1. Open Screen Resolution by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Choose one of the following:
    • Smaller - 100% (default). This keeps text and other items at normal size.
    • Medium - 125%. This sets text and other items to 125% of normal size.
    • Larger - 150%. This sets text and other items to 150% of normal size. This option appears only if your monitor supports a resolution of at least 1200 x 900 pixels.
  3. Click Apply.
May 25, 2014 | Computers & Internet
Permanently delete text messages from iPhone
iPhone Data Eraser would definitely erase your current data and permanently delete iPhone messages, but you can always protect your iPhone's data by using a backup recovery software.
Feb 12, 2013 | Apple iPhone Cell Phones
How can I set the computer text and icon settings permanently? I've set it at 125% but everytime I log in it goes back to 100%
Go into Control panel - Display - Settings tab - then in Screen resolution reduce the screen resolution say 1024 X 768.
Jun 07, 2012 | Acer Computers & Internet
How to change icon size
1. Click the Start and then choose the Control Panel option.
2. Control Panel window opens up. Click Display. 3. Choose one of the following:
Smaller - 100%. This keeps text and other items at normal size.
4. Click Adjust Resolution in the left pane, window opens up as below. 5. Click Set custom size text (DPI) in the left pane to customize the text size.
Drag the ruler with your mouse to increase or decrease the percentage.
Click Ok.
Click Apply in the main Display Window. click Log off now to save changes.
Sep 03, 2011 | Dell Computers & Internet
How to change text size to be larger
This depends upon what program you are running.
If you mean the Internet, you can change the view settings on most browsers by zooming in (go to "View" in your toolbar).
If it's a Microsoft application like "Word" or "Excel", you can increase the font size or the magnification of the document - again, from the toolbar.
Mar 03, 2011 | Computers & Internet
Printer using small type font size when printing from web pages
I am sorry to say that font size cannot be changed from the All-in-One software. It can only be changed from the application which you are using to print.
you can use Smart Web printing software to print webpages:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00793678&cc=us&lc=en&dlc=en
also, perform the steps below:
Change Text Size in Internet Explorer
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Size" option from the drop down menu. Use the mouse or press the x key.
A sub menu option window will appear containing the following five choices: "Largest", "Larger", "Medium", "Smaller" and "Smallest". "Medium" is the default value.
3. Select from among the five options by using the mouse to highlight or by pressing the appropriate keyboard letter, i.e. g for "Largest", l for "Larger", m for "Medium", s for "Smaller" or a for "Smallest."
The size of the text displayed in the browser window will change in accordance with your choice.
Change Text Size in Mozilla/Netscape 6+
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or Windows users can press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu window will appear containing three sets of options for changing displayed text size:
a. Increase or decrease the text size by small amounts. Select either the "Smaller" or the "Larger" option. Use the mouse to select "Smaller" or "Larger"; alternatively, press the appropriate
shortcut: CTRL - (minus) for "Smaller", CTRL + (plus) for "Larger". The size of text displayed in the browser window will increase or decrease by small amounts in accordance with your choice.
b. Change the text size to one of 7 pre-defined percentages of the default: 50, 75, 90, 100, 120, 150 and 200 percent. Select from among the 7 pre-defined percentages. Use the mouse to highlight your choice or the appropriate keyboard short cut, i.e. 5 for 50%, 7 for 75%, 9 for 90%, z for 100% (the default), 1 for 120%, 5 for 150% or 2 for 200%.
c. Change the text size to an arbitrary percentage of the default, e.g. 300%, 37.5%.
Select the "Other Options" menu item. Use the mouse to highlight your choice or press the o shortcut key.
A pop up input window titled "Text Zoom" will appear.
Type in the percentage amount by which you wish to change the default text size. Click on OK or press the ENTER key.
The size of the text displayed in the browser window will change in accordance with the value you enter in the input field.
These three options may be used separately or in combination.
Change Text Size in Firefox 1.0
1. From the Firefox Menu Bar select View>Text Size>Increase
2. This will cause the text to display on the web page one size larger. However this is a temporary change.
Or use the keyboard:
1. Press Ctrl & +/-, or Ctrl & scroll down/up to increase/decrease the text size.
To make a permanent font size change:
1. From the Firefox Menu Bar,
a. Windows: select Tools>Options. Select 'General'
b. Macintosh: select Preferences.
2. Click on 'Fonts & Colors'.
3. Set the font sizes. Minimum font size.can also be set.
Change Text Size in Opera
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse to make a selection or press the ALT + v shortcut keys. A drop down menu will appear.
2. Select the "Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu will appear containing the following options: 50, 80, 90, 100 (the default), 120, 150, 200 percent. In addition, there are four more options that make percentage increments or decrements to text size: -100, +100, -10 and +10 percent.
Select from among the options by using the mouse to highlight your choice.
* Alternately, use the + (plus) and - (minus) keys on your keyboards number pad, or the Zoom selector in the toolbar.
Mar 15, 2009 | HP PSC 2355 All-In-One InkJet Printer
How to increase the font size when printing?
Notepad and Microsoft Word
Please perform the steps given below, if you are printing from note pad nd Microsoft word:
Click on Format.
Click on Font.
Select the desired font under Size.
If you are printing from any browser, then I request you to perform the steps given below to change the font settings in differ browsers.
Following are the instructions to decrease or increase the font size in various browsers:
Dec 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer font size
Click on Format.
Click on Font.
Aug 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Size of font on the printed page too small
It depends on the print settings of the application but not All-in-One software.
Please perform the steps below to resolve:
Click on Format.
Click on Font.
Jul 15, 2008 | HP Photosmart C6100 All-In-One Printer
Computers & Internet Logo
44 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
