Click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down
image devices you could see a yellow question mark?
right click to reinstall drivers or update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select
the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
hope this helps you
SOURCE: i have bought a new msi cr 620 how to enable and
Function keys are used in a sequence such as Fn/F1,,FN /F4 etc .Function differs with each brand of pc check model site for exact hotkey definition
SOURCE: i need to install driver
Hi
www.msi.com
support
But have you tried to press FN+F6 to enable the webcam
or
HOPEFULLY TO INSTALL WEBCAM
START
ALL PROGRAMS
ARCSOFT WEBCAM COMPANAIN
LAUNCH UTILITY ARCSOFT WEBCAM
INSTALLING WEBCAM AND SOFTWARE?
THEN YOU SHOULD SEE DRIVER SOFTWARE
INSTALLED CORRECTLY
NOW GO BACK TO
START
ALL PROGRAMS
ARCSOFT WEBCAM COMPANIAN 3?
NOW HIGHLIGHT THE WEBCAM COMPANION 3 ( WITH PICTURE OF WEBCAM )
RIGHT CLICK IT AND GO TO SEND TO
THEN SEND IT TO THE DESKTOP ( CREATE SHORTCUT )
IT SHOULD THEN ON DESKTOP FOR FUTURE EASY USE TO TAKE SNAPSHOTS
many thanks
