Question about Ranger Communications RCI-6900F-25 CB Radio
Starts but not stay running - Ranger Communications RCI-6900F-25 CB Radio
Posted by jeff kent on
Melanie Rogers
    Champion:
  • 219 Answers
When you say it starts but doesn't stay running does that mean it goes right back off or does it go off random. If it goes right back off it could be several different things such as bad soldier or voltage regulator. If it does it at random I'd say first thing look for bad soldier around regulator its on the side of the radio 3 legs attached to side. One of these legs will get unattached because of using your side screws and tighting them to tight.
Posted on Jul 16, 2012
My cub cadet 1046 riding lawnmower won't stay running. I've replaced the fuel filter, both spark plugs, and sprayed carburetor ports with carburetor cleaner and it starts but won't stay running.
When you say "stay running", how long does it actually run for? Will it ALWAYS start and run, even if it dies, or will it sometimes not run at all and only turn over?
Mar 21, 2017 | Cub Cadet Garden
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Dec 15, 2016 | Cars & Trucks
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Truck starts but won't idle. If I stay on the gas pedal it will keep running untell it warms up if I turn lights or heater on it dies right away also please help
Need help: Truck starts but wont stay running?? - FullSizeChevy.com
www.fullsizechevy.com > ... > Technical / Maintenance
Jun 19, 2005 - 17 posts - ‎9 authors The truck will start but then die right out. I can do this all day long with the same effect. I can however keep it running by feathering the throttle. if ...
Truck starts but won't stay running...?? - Dodge Dakota Forum
Nov 30, 2015 | Cars & Trucks
Have a 95 olds lasaber starts but doesnt stay running
Well put some gas in it man! No, seriously, a vehicle runs on the physics of three principles. Fuel, air and ignition or "explosion" of gases. You have eliminated two of these principles since the engine "starts" but will not stay running. Most likely because of it lacking "fuel" or the pressure thereof. Only two things to check. Fuel pump, and filter.
Aug 31, 2012 | Chevrolet Cars & Trucks
My three wheeler doesn't stay running when it starts. What could be the problem besides the fuel line . just added a fuel filter on it but she still won't start or stay running at times. Co
The damage is already done before you put the fuel filter in. (dirt in Carb)
Remove your carb and dissesemble it and clean everything out and then put back on the machine with FRESH gas and you will be fine...run like a top !
Jul 06, 2012 | Cars & Trucks
Car wont stay running after initial start up?
Will it stay running if you keep the pedal depressed. If so you have a Idle Air Control valve issue. If it wont run at all it may be a bad fuel pump
Jul 14, 2009 | 1991 Chrysler Imperial
Will the car stay running if the batterie is disconected
It should stay running. If your alternator is bad it may not stay running but in all cases it should stay running.
May 14, 2009 | 1999 Chevrolet Venture
1989 Mazda b2200 starts but won't stay running
My mazda b2200 starts and will stay running as long as the key is in the start position, but stops as soon as the key is turned from the start position
Feb 07, 2009 | 1989 Mazda 323
Won't stay running
sounds like you have a bad ECU unit. have it checked.
Dec 28, 2008 | 2002 Jeep Grand Cherokee
Ranger Communications RCI-6900F-25 CB Radio Logo
50 people viewed this question
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
