Question about Sharp G1324SC Remote Control
I need the code for g1324sc sharp tv
I have a sharp tv remote, g1324SC and i need the code to program the tv. thanks it's a sharp tv, just need the code
Posted by sulph_69 on
    Top Expert:
  • Sharp Master
  • 76,407 Answers
Setup codes for Sharp TV are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Posted on Jul 15, 2012
1 Related Answer
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: I NEED INSTRUCTIONS AND CODE TO PROGRAM REMOTE TO
Try www.remotecodelist.com they may be able to help.
hardrocko
Posted on Feb 01, 2010
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
We have an old Sharp TV and lost the remote control. Can I use an RCA remote control to operate the Sharp TV - and what codes would I need - and how to do it. Thanks
I don't know from which country you are? But remote control of almost every TV is available in electronics spare part market. Just check it in your country. All that you have to do is carry your old remote control with you while purchasing a new one. It is better to tell them the make & model number of the TV.
sonsunny
Jun 17, 2011 | Sharp Televison & Video
I want to buy a new one, any possible suggestion, where i can get one?
hello ging....go to this link http://www.remotes.com/ I use it quite often and the replacements are factory originals. Joe
Jun 05, 2011 | Sharp G1324SC Remote Control
My tv doesn't respond to remote
Please replace the batteries with new ones and retry it. If does not work : Check your remote receiver on tv and the remote itself for malfunction. Dissemble your remote , check the DIODE for crack or damage and replace if needed with same model / type of diode. Suggestion is to has it fixed at repair shop in the receiver on TV get problem.
Regards
Jan 17, 2011 | Sharp G1324SC Remote Control
How do I program ESPN game changer remote control
I have the instruction book. What devices are you looking to proggram - type and brand??
Nov 21, 2010 | Televison & Video
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Jul 09, 2009 | RCA Universal Remote Control
Need to program sharp tv, no codes, manual lost
here's a link to the manual in pdf format: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc43304devicebigeasy&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4330-manual.zip
Jun 03, 2009 | One For All URC-4330 Remote Control
Need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
Jun 02, 2009 | DISH Network IR Remote Control
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
Jan 01, 2008 | One For All URC-3021 Remote Control
Comcast remote code for 42in sharp aquos lcd
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
Dec 14, 2007 | Televison & Video
Sharp G1324SC Remote Control Logo
462 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
