JVC AV-32120 32" TV Logo
Question about JVC AV-32120 32" TV
Can not turn on with power button
Power button or fuse?
Posted by Paul Murray on
2answers
Where would the fuse be located on my 55 inch hisense tv
Unplug the TV's power cord and hold the power button directly on the tv ,keep holding it for 20 secs or so then let the tv sit unplugged for a couple of minutes before you try it again.
1helpful
Philips Hi Fi unit model HTS3357.l not switch on.No lights.Press stand by switch.....Nothing.Checked plug power fuse and internal 20mm fuse both read ok/any ideas would be appreciated Oliver
Check the batteries on your remote, make sure they are installed on the right way. Your unit is on stand-by, meaning it is waiting for it to be turned on. Also try your power button. If that does not work, push the power button and disconnect from the wall. Keep pushing the power button for 1 minute. After that, release button, plug back in.
Good luck.
My thermoking 41-7784 power inverter will not turn on after pressing power button. What do I need to check next...fuses?
Look for the red reset button. Think there are two of them on these units. Could be wrong on that but do seem to recall that they have a reset button on the unit someplace. And check the fuse panel for blown fuses.
How do you reset
When you say a power reset button, do you mean the power button you turn on to power it up or a fuse? I doubt any coffee maker has a fuse any longer. If it does have a fuse, it's internal and you'll have to dismantle the coffee maker and find a replacement. You can find some fuses real cheap at Walmart.
1helpful
Have 2005 yamaha roadstar wont start no power. Batterie and fuses are good any idea what would cause this
Here are a few things to try to help you diagnois your problem.
1.Check for corrosion on battery terminals and the fuses.
2.Fuses are good - Did you check the fuse on the top of the solenoid?
3. Take a screwdriver and jump the solenoid wires to start the engine. If it starts, then your starter is good. (could be a bad solenoid - but lets check some wires first)
Your solenoid operates when you hit the start button.
Your start button won't work until you turn the on/off switch on.
Your on/off switch only has power when you turn the key on.
4 Use a test light to test the following:
Right Handlebar switch house - Test to see if you have power to on/off switch - Turn your ignition key on & off to see the testlight come on - if light comes on that means your igntion switch is good. If no light, the problem is in the igntion switch. or the main fuse to the igntion switch is bad.
If the light came on then you have power to one side of the on /off switch - test the on /off switch by turning it on and off. When switched to on you should have power to the other side of the on/off switch which is sending power to the rest of the bike which includes your starter button.
Test your start button with the test light by putting the test light on the solenoid - Turn key on - turn on/off switch on - push start button and see if the test light lights up. If the test light lights up that means that your solenoid fuse may be bad. It is located right on the top of the solenoid. If the fuse is good then that means your solenoid is bad. Replace it with a new one.
If the Test light did not come on then your starter button is not making contact and needs fixed or replaced.
So follow the power with the test light until through each component until you come to the faulty one.
NOTE: If its a blown fuse, check your wiring. You'll have to find out why the fuse blew and fix it or your fuse will just blow again. Could be a short somewhere, installing a battery wrong will blow fuses.
The power buttons doesnt turn off and is there a
there is a power button on your deck, but you must get to the screen where the clock is, touch the button and it will shut off, if not then we need to trouble shoot the situation, which is easy, if you take out your deck. and if you can find the blue wire w/ the white stripe that is located on your deck this is your remote wire, this cut the deck on and off, when hooked up properly, first your gonna need to extend this wire, so it can reach the fuse panel, then you need to locate the fuse that says cigarette lighter, pull the fuse out, and stick the extended remote wire there, then reinsert the fuse. now the deck should be off, now if you put the key in and turn it to on, the deck will come on, and when you turn the car off, it will swtay off, this will work i bet my rep on it.
Onkyo TX-DS777 Problem
man I think i have the same problem....
i push the power button but immediatly the LED turns off. I cheked the fuse but thats not the problem. Please if you solve your problem let me know...
my e.mail adress [email protected]
sorry if you dont undersatnd me in some parts..im not very good writting english haha sorry..
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
1helpful
2answers
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sharp TV
It could be a blown fuse, sometimes when power is restored a power spike occurs this can blow fuses in appliances. Check power to either side of main fuse. Then progressivly check all other minor fuses Cheers Paul
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
